No Boot, only 5vdc light
Dinosaur1946
Post by Dinosaur1946 »
Hi All
Have just received the second BBB's Rev.C from Adafruit and as I did on the first, I erased the MMCBLK1 so that it would
not boot on it and not interfere with the libpruio.
Used a good uSD and did: sudo dd if=/dev/zero bs=512 count=1024 of=/dev/mmcblk1
Once that was completed, sudo reboot.
However, the only light that was On and stayed on was the 5vdc power adapter.
Usually after a few sec's delay all 4 led's come on and the sequence starts.
Nothing, no amount of button pressing will bring it back to life.
Have of course confirmed the uSD on the other unit and all is ok.
The unit has not even had any connections other then the power.
Is this a warranty issue, how do I even go about that ?
Regards
Dinosaur
Does anyone have any suggestions (other then the garbage bin) as to how this "New" unit can be
recovered.
Dinosaur1946
Re: No Boot, only 5vdc light
Hi All
Problem solved.
By writing a Etcher console image, the BBB recognised it and booted.
Every time there after, my gui images loaded again.
So obviously something gets written with the console image that allows
future booting from other images.
Regards
Return to “Beagle Bone & Adafruit Beagle Bone products”
