Help with PCB design
Chat about pick and place machines, reflow ovens, assembly techniques and other SMT tips & trix
joshawatt
Post by joshawatt »
I hope this is the right channel to ask this question, if not please let me know!
I am trying to design a circuit that uses the micro:bit edge connector (this one: https://www.adafruit.com/product/3888 ). I have never designed a PCB like this before because from what I have found there are no pre-built boar layouts for this item. How would I go about making it on say jlcpcb (that is what I use but I also have Eagle if that is a better way to do it). I have the datasheet for it as well, however I don't know the units of measurement, I assume it is in millimeters. (and now that I think about it, I will just measure it once I get home). I tried to create SMD pads in JLCPCB but I could not get it to route any connections.
adafruit_support_mike
Re: Help with PCB design
I'm afraid we don't know anything about JLCPCB, but we have a couple of tutorials about creating device footprints in Eagle:
https://learn.adafruit.com/creating-acc ... s-in-eagle
https://learn.adafruit.com/ktowns-ultim ... e-tutorial
Those walk through all the steps necessary to transfer measurements from the datasheet to a layout package, and then assign the connections the way Eagle does it.
dmpyron
Post by dmpyron »
There are several rather sound YouTube videos on the basics but beware of the c**p. I've found that starting from functional blocks and going to netlists and then having the software build your schematics saves a lot of grief. You'll likely have to do some of the floorplanning yourself as most of the routing software can still leave you with less than optimal designs. But with a little thought and learning you can do it. I learned a lot working as the sysadmin for a bunch of overachievers at AMD.
Try a small, simple design. Don't fab it, just go through DRC to make sure you understand what you're doing. It's not "easy" and it's certainly not "obvious to the casual observer" nor a "trivial exercise left to the reader", but it is doable. When I was in undergrad the EEs were still learning how to design ICs on drafting boards. The 8080 was done that way and look at what that got us.
Return to “SMT (Surface Mount Tech)”
