I have purchased this board to prototype test a TSSOP 6-pin current sensor. My application requires pretty high locational tolerancing of the sensor and I was wondering if anyone knew what the exact dimensions and tolerances for this:
https://www.adafruit.com/product/1212
Adafruit board is. Would ask adafruit directly but all tech support is supposed to be through the forum. Thank you all for the help!
Dimensions of Adafruit Breakout Board
- Franklin97355
Re: Dimensions of Adafruit Breakout Board
If you've purchased the board you should be able to measure the dimensions. Since you have to place the chip yourself precise measurements depend on your placement.
The design files are over in our Github repo:
https://github.com/adafruit/Adafruit-SMT-Breakout-PCBs
You can pull any dimensions you need from those.
