RE: ADC and BeagleBone Python Library
silver2row
Post by silver2row »
Okay. So, I set up the adc subsystem like this:
ADC.setup()
Is there a way to stop or cease this setup of the ADC subsystem on the BBB w/ this library?
Seth
drewfustini
Re: RE: ADC and BeagleBone Python Library
Post by drewfustini »
I'm sorry but I don't understand what you mean by stop. Do you mean disable the ADC? Could you describe more of what you are trying to accomplish?
silver2row
Sure. I will try to explain further.
I wanted to turn off the AIN pins on the BeagleBone Black/Green/Wireless/etc w/ your library but I was not sure if that was possible.
Seth
P.S. I just remembered that the AIN pins run continuously.
drewfustini
The simplest solution I think would to use config-pin to change the mode of the ADC pins to another pinmux like GPIO.
silver2row
Alright, I always thought those pins were not able to be changed via config-pin or a .dts file.
Anyway, no issue.
Seth
Return to “Beagle Bone & Adafruit Beagle Bone products”
