I have a device with 2mm female header on the board, that I need to connect to a 2.54mm male header.
From the datasheet, I can see that this header has 2mm pitch, 0.5mm diameter pins on the male end - exactly what I need. However, what I can't tell from the datasheet, is whether the female/socket end of this adapter is intended for 0.5mm or 0.6mm pins.
My thinking is, if it's for 0.6mm pins, then I can simply use existing jumper wires with this adapter to connect it to my other device. Is this correct?
My other option is to get the 2.54 to 2mm female/female jumper wires, in combination with some 2mm header pins to act as a female/female adapter, but I have been struggling to find a European supplier which has both of those items in stock.
Thank you in advance for your help.
2mm 10 pin Socket Headers (for XBee) (ID 366)
Re: 2mm 10 pin Socket Headers (for XBee) (ID 366)
The 2mm pitch headers are designed to accept 0.5mm pins.
They will work with 24AWG wire which is 0.51mm dia. I believe the equivalent metric size is 0.22 mm^2.
