Good evening!
I have a BeagleBone AI and I can't flash the LED on pin P9_15.
I researched and verified that the mapping of the BB AI pins is different from the BBB.
Did you get a solution to this problem?
Thank you.
BeagleBone AI
- drewfustini
Re: BeagleBone AI
Please paste the commands or program that you are using to flash the LED and I will try try to reproduce the issue.
And please run this command and paste the results in your reply:
In addition, I would recommend downloading and trying the latest Debian image if you are not already:
AM5729 Debian 10.3 2020-04-06 8GB SD IoT TIDL image for BeagleBoard-X15, and BeagleBone AI
sudo /opt/scripts/tools/version.sh
- jgomes78
Re: BeagleBone AI
Good morning drewfustini!
I thank you for your attention, I did what you asked for, updated Debian, tried again to make the led blink on pin P9_15 and it didn't blink.
I am also sending the command response you asked for and the LED flashing program. In this program USR0, USR1, USR2 and USR3 flash, but output P9_15 does not respond.
Thank you.
#!/usr/bin/env node
// blinkLED.js
// Blinks the USR LEDs and P9_15.
// Wiring: P9_15 connects to the plus lead of an LED. The negative lead of the
// LED goes to a 220 Ohm resistor. The other lead of the resistor goes
// to ground.
// Setup:
// See:
const b = require('bonescript');
const leds = ["USR0", "USR1", "USR2", "USR3", "P9_15"];
for(var i in leds) {
b.pinMode(leds, b.OUTPUT);
var state = b.HIGH;
b.digitalWrite(leds, state);
setInterval(toggle, 100);
function toggle() {
if(state == b.LOW)
state = b.HIGH;
else
state = b.LOW;
git:/opt/scripts/:[b39ec679648a6be8f25f48bd1c9784c1fc5a0c46]
model:[BeagleBoard.org_BeagleBone_AI]
dogtag:[BeagleBoard.org Debian Buster IoT TIDL Image 2020-04-06]
UBOOT: Booted Device-Tree:[am5729-beagleboneai.dts]
kernel:[4.14.108-ti-r131]
nodejs:[v10.15.2]
/boot/uEnv.txt Settings:
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20200403.0-0rcnee0~buster+20200403]
pkg:[bb-wl18xx-firmware]:[1.20200322.0-0rcnee0~buster+20200322]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.4-git20190227.1-0rcnee0~buster+20190327]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyS0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 3.642924] remoteproc remoteproc0: 4b234000.pru is available
[ 3.643683] remoteproc remoteproc1: 4b238000.pru is available
[ 3.658217] remoteproc remoteproc2: BANNED.pru is available
[ 3.662158] remoteproc remoteproc3: BANNED.pru is available
[ 19.166466] remoteproc remoteproc4: 58820000.ipu is available
[ 19.176372] remoteproc remoteproc5: 55020000.ipu is available
[ 19.189863] remoteproc remoteproc6: 40800000.dsp is available
[ 19.220370] remoteproc remoteproc7: 41000000.dsp is available
[ 19.329163] remoteproc remoteproc5: powering up 55020000.ipu
[ 19.329210] remoteproc remoteproc5: Booting fw image dra7-ipu2-fw.xem4, size 3751356
[ 19.466434] remoteproc remoteproc4: powering up 58820000.ipu
[ 19.466483] remoteproc remoteproc4: Booting fw image dra7-ipu1-fw.xem4, size 7051536
[ 19.839136] remoteproc remoteproc5: registered virtio0 (type 7)
[ 19.839159] remoteproc remoteproc5: remote processor 55020000.ipu is now up
[ 19.868918] remoteproc remoteproc7: powering up 41000000.dsp
[ 19.868967] remoteproc remoteproc7: Booting fw image dra7-dsp2-fw.xe66, size 21014532
[ 19.879184] remoteproc remoteproc4: registered virtio1 (type 7)
[ 19.879208] remoteproc remoteproc4: remote processor 58820000.ipu is now up
[ 19.942439] remoteproc remoteproc7: registered virtio2 (type 7)
[ 19.942463] remoteproc remoteproc7: remote processor 41000000.dsp is now up
[ 20.036706] Modules linked in: omap_remoteproc virtio_rpmsg_bus rpmsg_core cmemk(O) uio_pdrv_genirq uio spidev pruss_soc_bus pru_rproc pruss pruss_intc usbhid
[ 20.037822] Modules linked in: omap_remoteproc virtio_rpmsg_bus rpmsg_core cmemk(O) uio_pdrv_genirq uio spidev pruss_soc_bus pru_rproc pruss pruss_intc usbhid
[ 20.059156] remoteproc remoteproc6: powering up 40800000.dsp
[ 20.059223] remoteproc remoteproc6: Booting fw image dra7-dsp1-fw.xe66, size 21014532
[ 20.178648] remoteproc remoteproc6: registered virtio3 (type 7)
[ 20.178671] remoteproc remoteproc6: remote processor 40800000.dsp is now up
dmesg | grep pru
[ 3.632316] pruss 4b200000.pruss: creating PRU cores and other child platform devices
[ 3.643005] pru-rproc 4b234000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@34000 probed successfully
[ 3.643732] pru-rproc 4b238000.pru: PRU rproc node /ocp/pruss_soc_bus@4b226004/pruss@0/pru@38000 probed successfully
[ 3.647007] pruss 4b280000.pruss: creating PRU cores and other child platform devices
[ 3.658277] pru-rproc BANNED.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@34000 probed successfully
[ 3.662229] pru-rproc BANNED.pru: PRU rproc node /ocp/pruss_soc_bus@4b2a6004/pruss@0/pru@38000 probed successfully
[ 34.410084] pruss_uio_shmem 4b200000.pruss_shmem: Allocating gdev
[ 34.410189] pruss_uio_shmem 4b200000.pruss_shmem: Allocating info
[ 34.410211] pruss_uio_shmem 4b200000.pruss_shmem: Requesting resource
[ 34.410376] pruss_uio_shmem 4b200000.pruss_shmem: Mapping resource
[ 34.411319] pruss_uio_shmem 4b200000.pruss_shmem: Registering with uio driver
[ 34.414375] pruss_uio_shmem 4b200000.pruss_shmem: Saving platform data
[ 34.415159] pruss_uio_shmem 4b280000.pruss_shmem: Allocating gdev
[ 34.415259] pruss_uio_shmem 4b280000.pruss_shmem: Allocating info
[ 34.415346] pruss_uio_shmem 4b280000.pruss_shmem: Requesting resource
[ 34.415404] pruss_uio_shmem 4b280000.pruss_shmem: Mapping resource
[ 34.415577] pruss_uio_shmem 4b280000.pruss_shmem: Registering with uio driver
[ 34.442375] pruss_uio_shmem 4b280000.pruss_shmem: Saving platform data
dmesg | grep pinctrl-single
[ 0.781755] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
dmesg | grep gpio-of-helper
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0c40:8000
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
END
Thank you.
#!/usr/bin/env node
// blinkLED.js
// to ground.
// Setup:
// See:
var state = b.HIGH;
function toggle() {
if(state == b.LOW)
state = b.HIGH;
else
state = b.LOW;
nodejs:[v10.15.2]
pkg:[kmod]:[26-1]
dmesg | grep remote
dmesg | grep pru
lsusb
END
- drewfustini
Re: BeagleBone AI
It is possible that P9_15 is not in gpio output mode.
Please run and paste the output:
Also, I have opened an issue in the bonescript repo to track this issue:
https://github.com/jadonk/bonescript/issues/189
/opt/scripts/device/bone/show-pins.pl
- jgomes78
Re: BeagleBone AI
Good Morning!
Here is the result of the command you presented to me.
Thank you.
P9.19a 16 R6 7 fast rx up i2c4_scl
P9.20a 17 T9 7 fast rx up i2c4_sda
P8.35b 57 AD9 e fast down gpio3_0
P8.33b 58 AF9 e fast down gpio3_1
P9.21a 60 AF8 e fast down gpio3_3
P8.12 67 AG6 e fast down gpio3_10
P8.11 68 AH4 e fast down gpio3_11
P9.15 69 AG4 e fast down gpio3_12
P9.26b 81 AE2 e fast down gpio3_24
P8.34b 89 G6 e fast down gpio4_0
P8.36b 90 F2 e fast down gpio4_1
P8.15a 92 D1 e fast down gpio4_3
P9.20b 94 D2 c fast rx up pr1_pru1_gpi1
P9.19b 95 F4 c fast rx up pr1_pru1_gpi2
P9.41b 96 C1 e fast down gpio4_7
P8.18 98 F5 c fast rx pr1_pru1_gpi5
P8.19 99 E6 c fast rx pr1_pru1_gpi6
P8.13 100 D3 c fast rx pr1_pru1_gpi7
P8.14 102 D5 e fast down gpio4_13
P9.42b 103 C2 e fast down gpio4_14
P9.27a 104 C3 e fast down gpio4_15
P9.14 107 D6 a fast down ehrpwm3A
P9.16 108 C5 d fast down pr1_pru1_gpo15
P8.15b 109 A3 d fast down pr1_pru1_gpo16
P8.26 110 B3 d fast down pr1_pru1_gpo17
P8.16 111 B4 d fast down pr1_pru1_gpo18
P8.28a 114 D11 e fast down gpio4_19
P8.30a 115 B10 e fast down gpio4_20
P8.29a 117 C11 e fast down gpio4_22
P8.27a 118 E11 e fast down gpio4_23
P8.45a 119 F11 e fast down gpio8_0
P8.46a 120 G10 e fast down gpio8_1
P8.43 121 F10 e fast down gpio8_2
P8.44 122 G11 e fast down gpio8_3
P8.41 123 E9 e fast down gpio8_4
P8.42 124 F9 e fast down gpio8_5
P8.39 125 F8 e fast down gpio8_6
P8.40 126 E7 e fast down gpio8_7
P8.37a 127 E8 e fast down gpio8_8
P8.38a 128 D9 e fast down gpio8_9
P8.36a 129 D7 e fast down gpio8_10
P8.34a 130 D8 e fast down gpio8_11
P8.35a 131 A5 e fast down gpio8_12
P8.33a 132 C6 e fast down gpio8_13
P8.31a 133 C8 e fast down gpio8_14
P8.32a 134 C7 e fast down gpio8_15
P8.45b 135 B7 e fast down gpio8_16
P9.11b 136 B8 e fast down gpio8_17
P8.17 137 A7 e fast down gpio8_18
P8.27b 138 A8 e fast down gpio8_19
P8.28b 139 C9 e fast down gpio8_20
P8.29b 140 A9 e fast down gpio8_21
P8.30b 141 B9 e fast down gpio8_22
P8.46b 142 A10 e fast down gpio8_23
P9.13b 160 AB10 f fast down Driver off
P9.26a 162 E21 e fast down gpio6_14
P9.24 163 F20 e fast down gpio6_15
P9.25 165 D18 e fast down gpio6_17
P8.09 166 E17 e fast down gpio6_18
P9.22a 167 B26 e fast down gpio6_19
P9.41a 168 C23 e fast down gpio6_20
P9.31b 169 C14 e fast down gpio7_31
P9.29b 170 D14 e fast down gpio7_30
P9.12 171 B14 e fast down gpio5_0
P9.27b 172 J14 e fast down gpio5_1
P9.18b 173 G12 e fast down gpio5_2
P9.17b 174 F12 e fast down gpio5_3
P9.31a 181 B12 e fast down gpio5_10
P9.29a 182 A11 e fast down gpio5_11
P9.30 183 B13 e fast down gpio5_12
P9.28 184 A12 e fast down gpio4_17
P9.42a 185 E14 e fast down gpio4_18
P8.10 186 A13 e fast down gpio6_4
P8.07 187 G14 e fast down gpio6_5
P8.08 188 F14 e fast down gpio6_6
P9.11a 203 B19 e fast down
P9.13a 204 C17 e fast down
P8.38b 205 C18 e fast down
P8.37b 206 A21 e fast down
P8.31b 207 G16 e fast down
P8.32b 208 D17 e fast down
P8.21 223 AD4 e fast down gpio6_29
P8.20 224 AC4 e fast down gpio6_30
P8.25 225 AC7 e fast down gpio6_31
P8.24 226 AC6 e fast down gpio7_0
P8.05 227 AC9 e fast down gpio7_1
P8.06 228 AC3 e fast down gpio7_2
P8.23 229 AC8 e fast down gpio1_22
P8.22 230 AD6 e fast down gpio1_23
P8.03 231 AB8 e fast down gpio1_24
P8.04 232 AB5 e fast down gpio1_25
P9.23 237 A22 e fast down gpio7_11
P9.22b 240 A26 e fast down gpio7_14
P9.21b 241 B22 e fast down gpio7_15
P9.18a 242 G17 e fast down gpio7_16
P9.17a 243 B24 e fast down gpio7_17
Thank you.
- drewfustini
Re: BeagleBone AI
Thanks, I'll add that to the github issue.
Could you try some of the other pins that have gpio in the right column?
P9.15 does appear to be in gpio mode, but it would be good to check it is the same problem with other pins too.
FYI - the convention is gpioX_Y where X is gpiochipX line Y, this is how it is organized internally inside the System on Chip [SoC].
- jgomes78
Re: BeagleBone AI
Good evening! There is a forum where you commented something about this problem. Thank you.
https://github.com/adafruit/adafruit-be ... issues/317
- drewfustini
Re: BeagleBone AI
That is true that Adafruit_BBIO, the Python library, does not yet support the BeagleBone AI.
However, Bonescript, the node.js javascript library, should work for the BeagleBone AI. That is why I opened the issue on the Bonescript repo.
- jgomes78
Re: BeagleBone AI
Good Morning!
I tried other GPIO's, but the following message appeared:
info: No pinmux for P9_15
(node:2228) [INSPECTOR_ASYNC_STACK_TRACES_NOT_AVAILABLE] Warning: Warning: Async stack traces in debugger are not available on 32bit platforms. The feature is disabled.
info: No pinmux for P9_18
error: Unable to write to /sys/class/gpio/gpio4/value
(node:2298) [INSPECTOR_ASYNC_STACK_TRACES_NOT_AVAILABLE] Warning: Warning: Async stack traces in debugger are not available on 32bit platforms. The feature is disabled.
info: No pinmux for P8_6
error: Unable to write to /sys/class/gpio/gpio35/value
(node:2469) [INSPECTOR_ASYNC_STACK_TRACES_NOT_AVAILABLE] Warning: Warning: Async stack traces in debugger are not available on 32bit platforms. The feature is disabled.
I also tried again on P9_15 and the same message appeared.
The USR LEDs flashed normally.
Grateful.
Grateful.
- drewfustini
Re: BeagleBone AI
Thanks for the information. I've added that to the bonescript github issue.
- jgomes78
Re: BeagleBone AI
Drew, good afternoon.
He managed to find something:
Grateful.
Grateful.
