I purchased a YBox2 kit a bit over a year ago, and have just gotten around to putting it together. I'm at the point where you insert both the Propeller chip and EEPROM, and then plug it in to a monitor and check for the bootloader screen. At this point, I get nothing. I've tried three different displays, including one old 5" "dumb" B&W tv, and I don't have any video. I soldered on the LED and buzzer, hoping that maybe I'd get some other indication of life, and maybe I just had a bridge somewhere in the video, but I don't get anything other than a very, very faint glow on the LED. I've stopped building the kit at this point.
I've been poking around with my ohm-meter looking for solder bridges, but I haven't found anything. I'm not an electronics person, but this isn't my first kit.
Any thoughts?
No video/blinkenlights/etc
Re: No video/blinkenlights/etc
post a photo of your kit top & bottom?
Here ya go
- Attachments
- P7062352.JPG (155.44 KiB) Viewed 9804 times
- P7062355.JPG (160.71 KiB) Viewed 9803 times
check the power supply, are you getting 3.3V?
also, install C8 that is necessary for the buzzer
Hi, im having the same problem but i do get 3.3V from the power supply. Also, the propeller chip gets very hot after a few seconds of it being plugged in.
Likewise. I get 3.26v but no video. (my cheap DMM may be a little off) There is no detectable heat being generated.
I went ahead and added a few more components after the failed test to see if it would at least make a noise or light the LED. No to both. I did read that C8 was needed for the buzzer (even though the instructions say that it is only for Ethernet) but have not installed it yet. I installed the jumper (haywire) between EEPROM pin7 and VSS and that didn't change anything. (I didn't expect it to, but???)
NEVERMIND
I removed and replaced both chips to check for bent pins... Not the problem. I retested and still no joy.
I finished the build and tested again. No difference. I figured I might as well clean up and try again later, so I removed the socketed chips and cleaned the flux off of the board (I use organic core, so just some warm water and an old toothbrush) and dried everything off. I came back a couple of hours later and installed all 3 chips and decided to try again.
Bleep, blinkblink, video is working...
<thud>
OK, so maybe it doesn't like having organic flux on the board? I've never known it to cause a problem before! (Yes, I know that if I leave it on that it can cause corrosion after a while, but I have never seen it cause a board to not pass a functional test.)
So I guess from here on I will solder, clean, test and not solder, test, clean.
Randy
NEVERMIND
<thud>
Randy
odd, but sometimes a chip isnt seated well or something (?) glad to hear its working now
True, but I had checked, pulled, and reseated both chips and still no joy. It only worked after I cleaned off the board (after finishing the build).adafruit wrote:odd, but sometimes a chip isnt seated well or something (?) glad to hear its working now
Have you ever built using organic "water soluble" flux before? Like I said, I have never had a problem before, but since I am not the first person to say "It didn't work until I finished the build" then that 'MAY' be something to look at. I unfortunately have no idea what the other user was building with.
I wish I had thought to try cleaning off the flux and testing again. That would have been telling.
Randy
we suggest only 'no clean' solder and flux as those will not damage the PCB
Well yes, you shouldn't use anything except "No-Clean" solder if you don't intend to clean the flux off of the board.
I personally prefer water soluble flux as it is REALLY easy to clean up and makes for a beautiful shiny solder joint. It only corrodes IF you don't clean up after yourself. It also takes quite a while before it has a detrimental effect. (and if you don't plan on cleaning, why pay extra for the organic core solder?)
While I personally prefer this it is just that, personal preference. I have used standard rosin core as well as "no-clean" and would not use no-clean again unless there was no other option. Rosin is good for me as long as I have a supply of solvent around. I like the look of a clean board. I am just AR that way I guess.
One thing I'm sure we can agree on is to use a GOOD quality solder. Cheap off-brand solder isn't worth the effort to toss it in the recycle bin. I'm a Kester fan myself.
Thanks for offering these kits. I finally cut out an Altoids tin and have the board installed. I decided to use the Dark Chocolate Creme de Menthe tin as I liked the design. (and the taste)
Randy
Randy
Organic flux is conductive.....Thats why i never use it...
a friend of mine went to town with organic flux on a PC board they were making/populating and it burnt out the WHOLE board...
NOT good stuff to work with...
