Bootloader Beta
Re: Bootloader Beta
What is the curl syntax for uploading the new bootloader?
Re: Bootloader Beta
Same as any other app:
Curl http://<IP of ybox>/stage2.eeprom -T bootloader.binary
I wouldn't do this if you don't have a prop plug.
Re: Bootloader Beta
I thought the bootloader was stage one (sort of) and stage two is the widget. Obviously I'm confused on this.
- presence
Re: Bootloader Beta
Darco's bootloader is really pretty fantastic. In this specific case, to update the bootloader, you upload the new bootloader as a "Stage 2" widget. When you push the button to load that "Stage 2" widget, the original old bootloader loads the new bootloader up as a widget. The new bootloader widget realizes that its job is to update the real bootloader and listens for that new bootloader from the curl command again.thetribster wrote:I thought the bootloader was stage one (sort of) and stage two is the widget. Obviously I'm confused on this.
You re-run that curl command to upload the new bootloader binary. The new bootloader widget picks it up, checks it out, and shoves that nice fresh bootloader into eeprom where it belongs. Give it a bit to settle down, then reboot. You'll be in new bootloader heaven. Upload a normal YBox2 widget like the alarm clock or Infowidget and you're in action.
If something honks, though, having the PropPlug or modded FTDI FT232RL cable is the only way to get happy again.
Re: Bootloader Beta
Thanks Presence, that made it easy. I did not know about the two curl commands.
The upgrade went perfectly, I am now on version 1.1a806 of the bootloader. Now to load a widget.
Re: Bootloader Beta
My yBox2 is now running v1.1a806. The upgrade went very smoothly, though i am yet to test widgets.
Just as well though, because i dont have a propplug!
Re: Bootloader Beta
The sample widgets work and i am loving the ability to set a static ip because before every time i rebooted a new address was assigned
Re: Bootloader Beta
I tried to switch to PAL and now every time it is turned on it freezes at the bootloader and displays
ybox2 bootloader v1.1a806
http://www.deepdarc.com/ybox2/
http://ladyada.net/make/ybox2/
The button wont do anything
The led is pulsating white
disconnecting then reconnecting power to the device does nost solve the problem
the device is not addressable on the static ip I set for it
just fixed it - reset mode still worked
- tooliktman^
Re: Bootloader Beta
How can i come back to the bootloader 1.0? i have also the cable similar to prop plug.
i'm a newbie of ybox2-
In bootloader 1.1 i'm not able to load the infowidget.
- darco
Re: Bootloader Beta
Did you try resetting the device by holding down the button for a long time while powering the device up?
- tooliktman^
Re: Bootloader Beta
Now it works was a problem of the server number. I have stange color led when i try the wwwexample wiget i dont get the right color if i click bluee i get green and so on.
What can be the problem?
- tooliktman^
Re: Bootloader Beta
Anyone can help me with this problem of the led color in the wwwexample widget?
- ex-h0trod
Re: Bootloader Beta
I believe this was discussed a while back, and turned out that some of the LED's had a different design such that they lit up differently than indicated in the example widget.Tooliktman^ wrote:Anyone can help me with this problem of the led color in the wwwexample widget?
