SIM Reader powered by the serial port
Is it possible to provide the vcc power supply from the vcc pin from the serial port?? Thanks in advance
Re: SIM Reader powered by the serial port
there isn't one. signal levels on a serial port are like +/- 10v.alandsilva wrote:Is it possible to provide the vcc power supply from the vcc pin from the serial port??
yes you can....
But the current is low, you have use the pin 4 and 5 to the db-9 ang link to 1n4148...or...take tehe vcc from the USB or another external vcc.
see my protobard
http://od-lambda.blogspot.com/2009/09/l ... s-232.html
see my protobard
This is basically why we invented USB... and that damn RS232 should be banished.
Get back to us on that after you've implemented a USB packet driver.minerva wrote:This is basically why we invented USB... and that damn RS232 should be banished.
There's a reason those FTDI cables and chips are worth their weight in gold.
