Product ID 3013 - Failures
For RTC breakouts, etc., use the Other Products from Adafruit forum
PeterD_ATG
Post by PeterD_ATG »
ADAFRUIT 3013 PURCHASES.GIF (21.39 KiB) Viewed 1247 times
We are an assembly facility who has been using your part# 3013 in a customer assembly.
We have purchase over 1200 units since 9/2019 and we have about 35 units from orders that are defective.
Can you please set up an RMA to send these back and can you replace these units.
adafruit_support_carter
Re: Product ID 3013 - Failures
Can you provide more information about the nature of the issue? How are they being used? What isn't working? etc.
PeterD_ATG
We are just an Assembly house here, so I don't know the technicals... But after installed we set the date and time, Then after re-boot, the unit does not hold the information and goes back to Default.
We would need to know more information about how these are being used. Do you have access to the software that is being used to set the date and time? Can you provide more information on the assembly they are being used in? Photos would help.
PeterD_ATG
I really do not have any more information for you. I do not want to be rude but, As you can see, we have used a large amount of these boards with no issues. In fact we have just ordered another 500 in the last week. The 35-36 boards we have just do not function correctly. I would just like for you to take them back, replace them, and stand by your product.
adafruit2
Post by adafruit2 »
hi we really dont mind replacing them ... but we use genuine maxim parts, they're extraordinarily reliable. if something is failing in installation, we strongly suspect something else is going on - likely some edge condition in the firmware! in that case, replacing them may help, or you may just get more failures.
if you want 36 replacements - email support@adafruit with a link to this thread.
however, we really really recommend an engineer does a root cause analysis, for long term success :)
PeterD_ATG
As requested I emailed support to get replacements for the initial 35 pcs that we had here that were deemed failed.
We never heard back anything except questions of why are they failing. We never received any mailing instructions or an RMA.
We now have an additional 15 pieces that have failed. We would really like to get replacements for all of these.
Please respond with an RMA and Replacements.
adafruit2
Post by adafruit2 »
hi, 15 more have failed from the initial batch after some time or?
email [email protected] with a link to this thread for RMA, check your spam folder, we reply within 1 business day
PeterD_ATG
These 15 New failed units are from two orders place this year, one in May and one in October of this year.
adafruit2
Post by adafruit2 »
kk did you get the email reply
Return to “Clock Kits (discontinued)”
