Macropad Speaker Shutdown
kirksan
Post by kirksan »
I’m not sure if this is the best forum for this but I’m hoping someone can point me in the right direction. I’ve started having errors with my Macropad, when I load code I get an error “Speaker Shutdown”. Code that ran correctly in the past, usually won’t run now. It’s not consistent, every once in a while I can get code to run but then that error comes back. I’m not using any sounds or tones.
adafruit_support_carter
Re: Macropad Speaker Shutdown
Can you link to the program you are running? Is it from a guide?
Return to “AdaBox! Show us what you made!”
