BEST 102C PROBLEMS
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
nmaludy
BEST 102C PROBLEMS
Post by nmaludy »
Received a Best 102C with my order #2733928-6895602727.
Tried using it today and had several issues:
First the tip refuses to tin (sign of issues to come). At max heat i wouls have to hold the solder on the tip for several seconds before it would start to bead, then would immediately drip off the tip and not stick.
Second, it never seemed like the iron got hot enough. I would hold the iron on the pad and headee for several seconds to heat it up, then bring in the solder and it wouldn't melt. In fact the solder needed to be held on the tip+pad junction for 15-20 (or more) seconds before the solder would melt. Ended up with several cold joint.
Help is appreciated,
Nick
Franklin97355
Re: BEST 102C PROBLEMS
Post by Franklin97355 »
Nick, Please contact [email protected] with a link to this thread and they will get you a refund for the soldering iron.
nmaludy
Post by nmaludy »
Franklin,
Done, thank you!
-Nick
Return to “Tools Tools Tools”
