Network Connected RGB Matrix Clock
For RTC breakouts, etc., use the Other Products from Adafruit forum
ishankum
Re: Network Connected RGB Matrix Clock
Post by ishankum »
also did by drag and drop between my pc and the matrix portal so tried that also then the correct file goes in
ishankum
Post by ishankum »
confirm mu is saving file correctly
dastels
Post by dastels »
ishankum
Post by ishankum »
finally got some output from mu serial
"Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
Press any key to enter the REPL. Use CTRL-D to reload.
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Matrix Portal M4 with samd51j19
soft reboot
code.py output:
Metro Minimal Clock
File "code.py", line 23, in <module>
KeyError: timezone
Code done running.
dastels
Post by dastels »
OK, that's a code (or configuration) error. Sounds like a bad map/dictionary key.
ishankum
Post by ishankum »
working now thank you
Return to “Clock Kits (discontinued)”
