WipperSnapper and Adafruit AHT20
adafruit.io wippersnapper BETA support, discussions, and more!
bcarlson
Post by bcarlson »
I've had an Adafruit ESP32-S2 Feather running WipperSnapper v1.0.0-beta.22 with an Adafruit AHT20 connect, to log temperature and humidity, it ran fine for a couple of weeks and then stopped uploading temperature and humidity updates, the ESP32-S2 Feather remained online. To troubleshoot I have removed the AHT20 component from the WipperSnapper board and removed the ESP32-S2 Feather as a WipperSnapper device and started all over adding the ESP32-S2 Feather back as a WipperSnapper device, the device showed online I then adding the AHT20 component. I then started the I2C scan, the scan completed and found address 0x38, with the temperature sensor and humidity sensor enabled I created the component. I got a green light on the AHT20 board and waited for over an hour and I still do not get temperature or humidity updates.
michimac
Re: WipperSnapper and Adafruit AHT20
Post by michimac »
Glad to hear I am not alone. Identical issue. I loaded the arduino example code for the ADT20 and confirmed I was getting a reading from both temperature and humidity. Everything shows up as described on Wippersnapper, but no data.
michimac
Post by michimac »
brubell
Learn User Page
Post by brubell »
michimac wrote:Glad to hear I am not alone. Identical issue. I loaded the arduino example code for the ADT20 and confirmed I was getting a reading from both temperature and humidity. Everything shows up as described on Wippersnapper, but no data.
What were the periods your sensors were set to? Every 15 minutes? Could you try setting them to "Every 30 seconds"?
michimac
Post by michimac »
Done. Feather shows online. No data from sensor.
redbishop
Post by redbishop »
Same issue on my end with the same hardware and firmware.
Screenshot 2022-01-26 171257.jpg (52.14 KiB) Viewed 349 times
michimac
Post by michimac »
Pretty sure it ain't us...
michimac
Post by michimac »
Now the server status seems fixed, but still no data.
redbishop
Post by redbishop »
Yes, same here. Device is still listed as online but No Data Yet.
nagrom78
Post by nagrom78 »
Same here no data showing up in my feed.
brubell
Learn User Page
Post by brubell »
redbishop wrote:Yes, same here. Device is still listed as online but No Data Yet.
nagrom78 wrote:Same here no data showing up in my feed.
michimac wrote:Now the server status seems fixed, but still no data.
Hi, this was a mistake on our end as we're working on adding more I2C sensors this week. It should be fixed now.
If you're still experiencing issues, please try deleting the sensor component and re-initializing it.
Thank you for reporting the issue and please let us know if it's working again for you.
michimac
Post by michimac »
Bingo. The data is flowing. Thank you!
redbishop
Post by redbishop »
Ok for me as well. Thanks for fixing.
How do we find out when new I2C devices are available in WipperSnapper?
brubell
Learn User Page
Post by brubell »
We'll blog when a new sensor is released - https://blog.adafruit.com/?s=wippersnapper
Return to “Adafruit IO Wippersnapper Beta”
