Adafruit dt-9205b+ won't measure volts or amps
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
brentschmidt
Post by brentschmidt »
Fuse checks good with another meter. Swapping leads didn't help either. It will, however, measure resistance. Is it salvagable?
rpiloverbd
Re: Adafruit dt-9205b+ won't measure volts or amps
Post by rpiloverbd »
If there is no luck after selecting the correct mode, then probably you got a problematic meter. Hope team adafruit will come forward to give you a good solution.
adafruit_support_mike
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
Return to “Tools Tools Tools”
