Huh, even the 8266 Huzzah can wippersnap
adafruit.io wippersnapper BETA support, discussions, and more!
brubell
Re: Huh, even the 8266 Huzzah can wippersnap
Post by brubell »
nerfzooka wrote:Thanks for your research, mrbubba. The arduino serial monitor check is a good idea. Just to see if my Huzzah could connect to my local WiFi I ran the arduino sketch HelloServer. It made a webpage on my network with no errors. So WiFissid and WiFipassword are ok. I'm going to check the other WipperSnapper Credentials more carefully.
Did you try this sketch: https://learn.adafruit.com/adafruit-fea ... 2720763-33
nerfzooka
Post by nerfzooka »
Hi brubell! This sketch works fine.
15:56:28.118 -> This is a test of Adafruit WiFi!
15:56:28.118 -> If you can read this, its working :)
15:56:28.118 -> closing connection
15:56:33.129 -> connecting to wifitest.adafruit.com
15:56:33.182 -> Requesting URL: /testwifi/index.html
15:56:33.683 -> HTTP/1.1 200 OK
15:56:33.683 -> Server: nginx/1.18.0 (Ubuntu)
15:56:33.683 -> Date: Fri, 25 Mar 2022 19:56:33 GMT
15:56:33.683 -> Content-Type: text/html
15:56:33.683 -> Content-Length: 69
15:56:33.683 -> Last-Modified: Thu, 09 Dec 2021 17:26:22 GMT
15:56:33.683 -> Connection: close
15:56:33.683 -> ETag: "61b23c3e-45"
15:56:33.683 -> Accept-Ranges: bytes
brubell
Post by brubell »
To verify, you are using a Feather ESP8266?
Are you sure you selected the correct board on https://adafruit.github.io/WipperSnappe ... _Uploader/ and that all the credentials look correct?
Can you try this with another WiFi network (possibly a mobile hotspot)?
nerfzooka
Post by nerfzooka »
Thank you brubell, I started over again using your link and the ESP8266 is detected this time. Yay! :)
Return to “Adafruit IO Wippersnapper Beta”
