2v support
DCInnovation
2v support
Post by DCInnovation »
I purchased a USBtinyISP to program a board where Vcc is 1.8v. After pounding my head against a wall for a while a stripped the parts off that couldn't go above 1.8v and left the microcontroller. I noticed that It wouldn't program below 2.6v and finally visited the HELP! section of the webpage and saw that it won't work below 2.5v.
Why is it advertised to program boards below 2.5v if it can't? or am I missing something?
Sincerely,
-Confused
Franklin97355
Re: 2v support
Post by Franklin97355 »
What are you trying to program and where did you find the info about the voltage below which it would not program?
DCInnovation
Re: 2v support
In the help section. I am planning to simply add either a level shifter to the device or lower the 5v rail to 3.3v
DCInnovation
Re: 2v support
Not sure if it will run on 3.3v though because of the 12mhz clock speed
Franklin97355
Re: 2v support
According to the documents
"Version 2.0 which is almost certainly what you've got, uses a level shifter so that if the jumper is not in place, it will use whatever the target voltage is, a lot better for your low-voltage devices!
So, if you have a device that needs to run at 3.3V, don't have the jumper in place!"
So you power the USBTinyISP with 5 volts but not the chip. Is that what you are doing?
adafruit2
Re: 2v support
Post by adafruit2 »
its been a very long time but we dont know we've programmed 2V boards with the usbtinyisp, where does it say it does?
DCInnovation
Re: 2v support
Looks like it can based on the datasheet! Hopefully this works and helps others
adafruit2
Re: 2v support
Post by adafruit2 »
ok the chip's datasheet isnt the same as the product datasheet or specifications. e.g. if a tire is rated to 250mph that doesnt mean the car can go 250 mph.
DCInnovation
Re: 2v support
Okay hopefully this helps someone out there. I was able program a 1.8v target by cutting the trace that connects the system to 5v, and soldering wires to a 3.3v source. when the microcontroller is powered by 5v the minimum voltage on a pin is 2.5 to get a logic high. That is why the help section says to use a 2.5v minimum target ("capture2.png" attachment).
Once I got the 3.3v power to the microcontroller it registers 1.8v as a logic high.
The product page makes it sound like 2v is supported out of the box. Perhaps this is due to batch variations.
Let me know if you need more info!
adafruit2
Re: 2v support
Post by adafruit2 »
where does it say 2V is supported? we'll update the text
Return to “USBtinyISP”
