I've gotten the dotStar strip to work already. But not the code from the bike wheel project, shown below.
The project appears to be written specifically for this controller. "Bike Wheel display with Pro Trinket" - Adafruit Pro Trinket - 5V 16MHz PID: 2000
I'm trying to comment them out, but they are used throughout the code. I'll have to dig deep here.
// SPDX-FileCopyrightText: 2019 Phillip Burgess for Adafruit Industries
// SPDX-License-Identifier: MIT
POV LED bike wheel sketch. Uses the following Adafruit parts:
- Pro Trinket 5V (www.adafruit.com/product/2000)
(NOT Trinket or 3V Pro Trinket)
- Waterproof 3xAA battery holder with on/off switch (#771)
- 144 LED/m DotStar strip (#2328 or #2329) ONE is enough for
both sides of one bike wheel
- Tactile switch button (#1119) (optional)
Needs Adafruit_DotStar library: github.com/adafruit/Adafruit_DotStar
Full instructions: [url]https://learn.adafruit.com/bike-wheel-pov-display[/url]
This project is based on Phil B's Genesis Poi:
learn.adafruit.com/genesis-poi-dotstar-led-persistence-of-vision-poi
and has been adapted to the Pro Trinket to accomodate more and larger
images than Trinket.
products from Adafruit!
Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
MIT license, all text above must be included in any redistribution.
See 'COPYING' file for additional notes.
#include <Arduino.h>
#include <Adafruit_DotStar.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <SPI.h> // Enable this line on Pro Trinket
#ifdef __AVR_ATtiny85__
typedef uint8_t line_t; // Max 255 lines/image on Trinket
#else
typedef uint16_t line_t; // Bigger images OK on other boards
#endif
// CONFIGURABLE STUFF ------------------------------------------------------
#include "graphics.h" // Graphics data is contained in this header file.
// It's generated using the 'convert.py' Python script. Various image
// formats are supported, trading off color fidelity for PROGMEM space
// (particularly limited on Trinket). Handles 1-, 4- and 8-bit-per-pixel
// palette-based images, plus 24-bit truecolor. 1- and 4-bit palettes can
// be altered in RAM while running to provide additional colors, but be
// mindful of peak & average current draw if you do that! Power limiting
// is normally done in convert.py (keeps this code relatively small & fast).
// 1/4/8/24 were chosen because the AVR can handle these operations fairly
// easily (have idea for handing arbitrary bit depth w/328P, but this margin
// is too narrow to contain).
// Ideally you use hardware SPI as it's much faster, though limited to
// specific pins. If you really need to bitbang DotStar data & clock on
// different pins, optionally define those here:
//#define LED_DATA_PIN 0
//#define LED_CLOCK_PIN 1
// Select from multiple images using tactile button (#1489) between pin and
// ground. Requires suitably-built graphics.h file w/more than one image.
#define SELECT_PIN 3
// Optional feature -- not enabled here, no space -- a vibration switch
// (aligned perpendicular to leash) is used as a poor man's accelerometer.
// Poi then lights only when moving, saving some power. The 'fast'
// vibration switch is VERY sensitive and will trigger at the slightest
// bump, while the 'medium' switch requires a certain spin rate which may
// not trigger if you're doing mellow spins. Neither is perfect. To leave
// that out and simply have the poi run always-on, comment out this line:
//#define MOTION_PIN 2
// Another optional feature not enable due to physical size -- powering down
// DotStars when idle conserves more battery. Use a PNP transistor (e.g.
// 2N2907) (w/220 Ohm resistor to base) as a 'high side' switch to DotStar
// +V. DON'T do this NPN/low-side, may damage strip. MOTION_PIN must also
// be defined to use this (pointless without).
//#define POWER_PIN 4
#define SLEEP_TIME 2000 // Not-spinning time before sleep, in milliseconds
// Empty and full thresholds (millivolts) used for battery level display:
#define BATT_MIN_MV 3350 // Some headroom over battery cutoff near 2.9V
#define BATT_MAX_MV 4000 // And little below fresh-charged battery near 4.1V
// These figures are based on LiPoly cell and will need to be tweaked for
// 3X NiMH or alkaline batteries!
boolean autoCycle = true; // Set to true to cycle images by default
#define CYCLE_TIME 10 // Time, in seconds, between auto-cycle images
#if defined(LED_DATA_PIN) && defined(LED_CLOCK_PIN)
// Older DotStar LEDs use GBR order. If colors are wrong, edit here.
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS,
LED_DATA_PIN, LED_CLOCK_PIN, DOTSTAR_BRG);
#else
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS, DOTSTAR_BGR);
#endif
void imageInit(void);
uint16_t readVoltage(void);
#ifdef MOTION_PIN
void sleep(void);
#endif
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000L)
clock_prescale_set(clock_div_1); // Enable 16 MHz on Trinket
#endif
#ifdef POWER_PIN
pinMode(POWER_PIN, OUTPUT);
digitalWrite(POWER_PIN, LOW); // Power-on LED strip
#endif
strip.begin(); // Allocate DotStar buffer, init SPI
strip.clear(); // Make sure strip is clear
strip.show(); // before measuring battery
// Display battery level bargraph on startup. It's just a vague estimate
// based on cell voltage (drops with discharge) but doesn't handle curve.
uint16_t mV = readVoltage();
uint8_t lvl = (mV >= BATT_MAX_MV) ? NUM_LEDS : // Full (or nearly)
(mV <= BATT_MIN_MV) ? 1 : // Drained
1 + ((mV - BATT_MIN_MV) * NUM_LEDS + (NUM_LEDS / 2)) /
(BATT_MAX_MV - BATT_MIN_MV + 1); // # LEDs lit (1-NUM_LEDS)
for(uint8_t i=0; i<lvl; i++) { // Each LED to batt level...
uint8_t g = (i * 5 + 2) / NUM_LEDS; // Red to green
strip.setPixelColor(i, 4-g, g, 0);
strip.show(); // Animate a bit
delay(250 / NUM_LEDS);
delay(1500); // Hold last state a moment
strip.clear(); // Then clear strip
strip.show();
imageInit(); // Initialize pointers for default image
#ifdef SELECT_PIN
pinMode(SELECT_PIN, INPUT_PULLUP);
#endif
#ifdef MOTION_PIN
pinMode(MOTION_PIN, INPUT_PULLUP);
sleep(); // Sleep until motion detected
#endif
// GLOBAL STATE STUFF ------------------------------------------------------
uint32_t lastImageTime = 0L; // Time of last image change
#ifdef MOTION_PIN
uint32_t prev = 0L; // Used for sleep timing
#endif
uint8_t imageNumber = 0, // Current image being displayed
imageType, // Image type: PALETTE[1,4,8] or TRUECOLOR
*imagePalette, // -> palette data in PROGMEM
*imagePixels, // -> pixel data in PROGMEM
palette[16][3]; // RAM-based color table for 1- or 4-bit images
line_t imageLines, // Number of lines in active image
imageLine; // Current line number in image
#ifdef SELECT_PIN
uint8_t debounce = 0; // Debounce counter for image select pin
#endif
void imageInit() { // Initialize global image state for current imageNumber
imageType = pgm_read_byte(&images[imageNumber].type);
imageLines = pgm_read_byte(&images[imageNumber].lines);
#else
imageLines = pgm_read_word(&images[imageNumber].lines);
#endif
imageLine = 0;
imagePalette = (uint8_t *)pgm_read_word(&images[imageNumber].palette);
imagePixels = (uint8_t *)pgm_read_word(&images[imageNumber].pixels);
// 1- and 4-bit images have their color palette loaded into RAM both for
// faster access and to allow dynamic color changing. Not done w/8-bit
// because that would require inordinate RAM (328P could handle it, but
// I'd rather keep the RAM free for other features in the future).
if(imageType == PALETTE1) memcpy_P(palette, imagePalette, 2 * 3);
else if(imageType == PALETTE4) memcpy_P(palette, imagePalette, 16 * 3);
lastImageTime = millis(); // Save time of image init for next auto-cycle
void nextImage(void) {
if(++imageNumber >= NUM_IMAGES) imageNumber = 0;
imageInit();
// MAIN LOOP ---------------------------------------------------------------
uint32_t t = millis(); // Current time, milliseconds
#ifdef MOTION_PIN
// Tried to do this with watchdog timer but encountered gas pains, so...
if(!digitalRead(MOTION_PIN)) { // Vibration switch pulled down?
prev = t; // Yes, reset timer
} else if((t - prev) > SLEEP_TIME) { // No, SLEEP_TIME elapsed w/no switch?
sleep(); // Power down
prev = t; // Reset timer on wake
#endif
if(autoCycle) {
if((t - lastImageTime) >= (CYCLE_TIME * 1000L)) nextImage();
// CPU clocks vary slightly; multiple poi won't stay in perfect sync.
// Keep this in mind when using auto-cycle mode, you may want to cull
// the image selection to avoid unintentional regrettable combinations.
#ifdef SELECT_PIN
if(digitalRead(SELECT_PIN)) { // Image select?
debounce = 0; // Not pressed -- reset counter
} else { // Pressed...
if(++debounce >= 25) { // Debounce input
nextImage(); // Switch to next image
while(!digitalRead(SELECT_PIN)); // Wait for release
// If held 1+ sec, toggle auto-cycle mode on/off
if((millis() - t) >= 1000L) autoCycle = !autoCycle;
debounce = 0;
#endif
// Transfer one scanline from pixel data to LED strip:
// If you're really pressed for graphics space and need just a few extra
// scanlines, and know for a fact you won't be using certain image modes,
// you can comment out the corresponding blocks below. e.g. PALETTE8 and
// TRUECOLOR are somewhat impractical on Trinket, and commenting them out
// can free up nearly 200 bytes of extra image storage.
switch(imageType) {
case PALETTE1: { // 1-bit (2 color) palette-based image
uint8_t pixelNum = 0, byteNum, bitNum, pixels, idx,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 8];
for(byteNum = NUM_LEDS/8; byteNum--; ) { // Always padded to next byte
pixels = pgm_read_byte(ptr++); // 8 pixels of data (pixel 0 = LSB)
for(bitNum = 8; bitNum--; pixels >>= 1) {
idx = pixels & 1; // Color table index for pixel (0 or 1)
strip.setPixelColor(pixelNum++,
palette[idx][0], palette[idx][1], palette[idx][2]);
break;
case PALETTE4: { // 4-bit (16 color) palette-based image
uint8_t pixelNum, p1, p2,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 2];
for(pixelNum = 0; pixelNum < NUM_LEDS; ) {
p2 = pgm_read_byte(ptr++); // Data for two pixels...
p1 = p2 >> 4; // Shift down 4 bits for first pixel
p2 &= 0x0F; // Mask out low 4 bits for second pixel
palette[p1][0], palette[p1][1], palette[p1][2]);
palette[p2][0], palette[p2][1], palette[p2][2]);
break;
case PALETTE8: { // 8-bit (256 color) PROGMEM-palette-based image
uint16_t o;
uint8_t pixelNum,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS];
for(pixelNum = 0; pixelNum < NUM_LEDS; pixelNum++) {
o = pgm_read_byte(ptr++) * 3; // Offset into imagePalette
strip.setPixelColor(pixelNum,
pgm_read_byte(&imagePalette[o]),
pgm_read_byte(&imagePalette[o + 1]),
pgm_read_byte(&imagePalette[o + 2]));
break;
case TRUECOLOR: { // 24-bit ('truecolor') image (no palette)
uint8_t pixelNum, r, g, b,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS * 3];
r = pgm_read_byte(ptr++);
g = pgm_read_byte(ptr++);
b = pgm_read_byte(ptr++);
strip.setPixelColor(pixelNum, r, g, b);
break;
strip.show(); // Refresh LEDs
#if !defined(LED_DATA_PIN) && !defined(LED_CLOCK_PIN)
delayMicroseconds(900); // Because hardware SPI is ludicrously fast
#endif
if(++imageLine >= imageLines) imageLine = 0; // Next scanline, wrap around
// POWER-SAVING STUFF -- Relentlessly non-portable -------------------------
#ifdef MOTION_PIN
void sleep() {
// Turn off LEDs...
strip.clear(); // Issue '0' data
strip.show();
#ifdef POWER_PIN
digitalWrite(POWER_PIN, HIGH); // Cut power
pinMode(1, INPUT); // Set SPI data & clock to inputs else
pinMode(2, INPUT); // DotStars power parasitically, jerks.
#else
pinMode(11, INPUT);
pinMode(13, INPUT);
#endif // ATtiny
#endif // Data/clock/pins
#endif // POWER_PIN
power_all_disable(); // Peripherals ALL OFF, best sleep-state battery use
// Enable pin-change interrupt on motion pin
PCMSK = _BV(MOTION_PIN); // Pin mask
GIMSK = _BV(PCIE); // Interrupt enable
#else
volatile uint8_t *p = portInputRegister(digitalPinToPort(MOTION_PIN));
if(p == &PIND) { // Pins 0-7 = PCINT16-23
PCMSK2 = _BV(MOTION_PIN);
PCICR = _BV(PCIE2);
} else if(p == &PINB) { // Pins 8-13 = PCINT0-5
PCMSK0 = _BV(MOTION_PIN- 8);
PCICR = _BV(PCIE0);
} else if(p == &PINC) { // Pins 14-20 = PCINT8-14
PCMSK1 = _BV(MOTION_PIN-14);
PCICR = _BV(PCIE1);
#endif
// If select pin is enabled, that wakes too!
#ifdef SELECT_PIN
debounce = 0;
PCMSK |= _BV(SELECT_PIN); // Add'l pin mask
#else
volatile uint8_t *p = portInputRegister(digitalPinToPort(SELECT_PIN));
PCMSK2 = _BV(SELECT_PIN);
PCICR = _BV(PCIE2);
PCMSK0 = _BV(SELECT_PIN- 8);
PCICR = _BV(PCIE0);
PCMSK1 = _BV(SELECT_PIN-14);
PCICR = _BV(PCIE1);
#endif // ATtiny
#endif // SELECT_PIN
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Deepest sleep mode
sleep_enable();
interrupts();
sleep_mode(); // Power down
// Resumes here on wake
// Clear pin change settings so interrupt won't fire again
GIMSK = PCMSK = 0;
#else
PCICR = PCMSK0 = PCMSK1 = PCMSK2 = 0;
#endif
power_timer0_enable(); // Used by millis()
pinMode(1, OUTPUT); // Re-enable SPI pins
pinMode(2, OUTPUT);
power_usi_enable(); // Used by DotStar
#else
pinMode(11, OUTPUT); // Re-enable SPI pins
pinMode(13, OUTPUT);
power_spi_enable(); // Used by DotStar
#endif // ATtiny
#endif // Data/clock pins
#ifdef POWER_PIN
digitalWrite(POWER_PIN, LOW); // Power-up LEDs
#endif
prev = millis(); // Save wake time
EMPTY_INTERRUPT(PCINT0_vect); // Pin change (does nothing, but required)
#ifndef __AVR_ATtiny85__
ISR(PCINT1_vect, ISR_ALIASOF(PCINT0_vect));
ISR(PCINT2_vect, ISR_ALIASOF(PCINT0_vect));
#endif
#endif // MOTION_PIN
// Battery monitoring idea adapted from JeeLabs article:
// jeelabs.org/2012/05/04/measuring-vcc-via-the-bandgap/
// Code from Adafruit TimeSquare project, added Trinket support.
// In a pinch, the poi code can work on a 3V Trinket, but the battery
// monitor will not work correctly (due to the 3.3V regulator), so
// maybe just comment out any reference to this code in that case.
uint16_t readVoltage() {
int i, prev;
uint8_t count;
uint16_t mV;
// Select AVcc voltage reference + Bandgap (1.8V) input
ADMUX = _BV(MUX3) | _BV(MUX2);
#else
ADMUX = _BV(REFS0) |
_BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#endif
ADCSRA = _BV(ADEN) | // Enable ADC
_BV(ADPS2) | _BV(ADPS1) | _BV(ADPS0); // 1/128 prescaler (125 KHz)
// Datasheet notes that the first bandgap reading is usually garbage as
// voltages are stabilizing. It practice, it seems to take a bit longer
// than that. Tried various delays, but still inconsistent and kludgey.
// Instead, repeated readings are taken until four concurrent readings
// stabilize within 10 mV.
for(prev=9999, count=0; count<4; ) {
for(ADCSRA |= _BV(ADSC); ADCSRA & _BV(ADSC); ); // Start, await ADC conv.
i = ADC; // Result
mV = i ? (1100L * 1023 / i) : 0; // Scale to millivolts
if(abs((int)mV - prev) <= 10) count++; // +1 stable reading
else count = 0; // too much change, start over
prev = mV;
ADCSRA = 0; // ADC off
return mV;
