I'm having the same issue I've had with other watchdogs timers I've tried in that once I add them the code just stops working. This one is at least rebooting the device as expected, but I can't get the timer to reset where it needs to or something. Maybe the wifi connection just takes longer than 8 seconds and I won't be able to use it in this sketch, which would be a shame. I want to turn this into a desktop device I can just leave running.
// SPDX-FileCopyrightText: 2019 Dan Cogliano for Adafruit Industries
// SPDX-License-Identifier: MIT
extern "C" {
#include "wdtFunctions.h"
#include <time.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ThinkInk.h>
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
#include <SPI.h>
#include <WiFiNINA.h>
#include "secrets.h"
#include "OpenWeatherMap.h"
#include "Fonts/meteocons48pt7b.h"
#include "Fonts/meteocons24pt7b.h"
#include "Fonts/meteocons20pt7b.h"
#include "Fonts/meteocons16pt7b.h"
#include "Fonts/moon_phases20pt7b.h"
#include "Fonts/moon_phases36pt7b.h"
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSans18pt7b.h>
#include <Fonts/FreeSansBold12pt7b.h>
#include <Fonts/FreeSansBold24pt7b.h>
#define SRAM_CS 8
#define EPD_CS 10
#define EPD_DC 9
#define EPD_RESET -1
#define EPD_BUSY -1
#define NEOPIXELPIN 40
// This is for the 2.7" tricolor EPD
ThinkInk_270_Tricolor_C44 gfx(EPD_DC, EPD_RESET, EPD_CS, SRAM_CS, EPD_BUSY);
AirliftOpenWeatherMap owclient(&Serial);
OpenWeatherMapCurrentData owcdata;
OpenWeatherMapForecastData owfdata[3];
Adafruit_NeoPixel neopixel = Adafruit_NeoPixel(1, NEOPIXELPIN, NEO_GRB + NEO_KHZ800);
reboot
This function forces the system to reboot immediately
void reboot(void) {
//*DBL_TAP_PTR = DBL_TAP_MAGIC;
//SCB->AIRCR = (0x5FA << SCB_AIRCR_VECTKEY_Pos) | SCB_AIRCR_SYSRESETREQ_Msk; // force reboot
__DSB(); // Ensure all outstanding memory accesses included
// buffered write are completed before reset
SCB->AIRCR = ((0x5FA << SCB_AIRCR_VECTKEY_Pos) |
(SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |
SCB_AIRCR_SYSRESETREQ_Msk); // Keep priority group unchanged
__DSB(); // Ensure completion of memory access
while (1); // wait until reset
} // reboot
const char *moonphasenames[29] = {
"New Moon",
"Waxing Crescent",
"Waxing Crescent",
"Waxing Crescent",
"Waxing Crescent",
"Waxing Crescent",
"Waxing Crescent",
"Quarter",
"Waxing Gibbous",
"Waxing Gibbous",
"Waxing Gibbous",
"Waxing Gibbous",
"Waxing Gibbous",
"Waxing Gibbous",
"Full Moon",
"Waning Gibbous",
"Waning Gibbous",
"Waning Gibbous",
"Waning Gibbous",
"Waning Gibbous",
"Waning Gibbous",
"Last Quarter",
"Waning Crescent",
"Waning Crescent",
"Waning Crescent",
"Waning Crescent",
"Waning Crescent",
"Waning Crescent",
"Waning Crescent"
int8_t readButtons(void) {
uint16_t reading = analogRead(A3);
//Serial.println(reading);
if (reading > 600) {
return 0; // no buttons pressed
if (reading > 400) {
return 4; // button D pressed
if (reading > 250) {
return 3; // button C pressed
if (reading > 125) {
return 2; // button B pressed
return 1; // Button A pressed
bool wifi_connect() {
wdtClear();
Serial.print("Connecting to WiFi... ");
WiFi.setPins(SPIWIFI_SS, SPIWIFI_ACK, ESP32_RESETN, ESP32_GPIO0, &SPIWIFI);
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
displayError("Communication with WiFi module failed!");
while (true);
String fv = WiFi.firmwareVersion();
if (fv < "1.0.0") {
Serial.println("Please upgrade the firmware");
neopixel.setPixelColor(0, neopixel.Color(0, 0, 7));
neopixel.show();
if (WiFi.begin(WIFI_SSID, WIFI_PASSWORD) == WL_CONNECT_FAILED)
Serial.println("WiFi connection failed!");
displayError("WiFi connection failed!");
return false;
int wifitimeout = 15;
int wifistatus;
while ((wifistatus = WiFi.status()) != WL_CONNECTED && wifitimeout > 0) {
wdtClear();
delay(1000);
Serial.print(".");
wifitimeout--;
if (wifitimeout == 0)
Serial.println("WiFi connection timeout with error " + String(wifistatus));
displayError("WiFi connection timeout with error " + String(wifistatus));
neopixel.setPixelColor(0, neopixel.Color(0, 0, 0));
neopixel.show();
return false;
neopixel.show();
Serial.println("Connected");
return true;
void wget(String &url, int port, char *buff)
int pos1 = url.indexOf("/", 0);
int pos2 = url.indexOf("/", 8);
String host = url.substring(pos1 + 2, pos2);
String path = url.substring(pos2);
Serial.println("to wget(" + host + "," + path + "," + port + ")");
wget(host, path, port, buff);
void wget(String &host, String &path, int port, char *buff)
//WiFiSSLClient client;
WiFiClient client;
neopixel.show();
client.stop();
if (client.connect(host.c_str(), port)) {
Serial.println("connected to server");
// Make a HTTP request:
client.println(String("GET ") + path + String(" HTTP/1.0"));
client.println("Host: " + host);
client.println("Connection: close");
client.println();
uint32_t bytes = 0;
int capturepos = 0;
bool capture = false;
int linelength = 0;
char lastc = '\0';
while (true)
while (client.available()) {
char c = client.read();
//Serial.print(c);
if ((c == '\n') && (lastc == '\r'))
if (linelength == 0)
capture = true;
linelength = 0;
else if (capture)
buff[capturepos++] = c;
//Serial.write(c);
else
if ((c != '\n') && (c != '\r'))
linelength++;
lastc = c;
bytes++;
// if the server's disconnected, stop the client:
if (!client.connected()) {
//Serial.println();
Serial.println("disconnecting from server.");
client.stop();
buff[capturepos] = '\0';
Serial.println("captured " + String(capturepos) + " bytes");
break;
else
Serial.println("problem connecting to " + host + ":" + String(port));
buff[0] = '\0';
neopixel.show();
int getStringLength(String s)
int16_t x = 0, y = 0;
uint16_t w, h;
gfx.getTextBounds(s, 0, 0, &x, &y, &w, &h);
return w + x;
return value is percent of moon cycle ( from 0.0 to 0.999999), i.e.:
0.0: New Moon
0.125: Waxing Crescent Moon
0.25: Quarter Moon
0.375: Waxing Gibbous Moon
0.5: Full Moon
0.625: Waning Gibbous Moon
0.75: Last Quarter Moon
0.875: Waning Crescent Moon
float getMoonPhase(time_t tdate)
time_t newmoonref = 1263539460; //known new moon date (2010-01-15 07:11)
// moon phase is 29.5305882 days, which is 2551442.82048 seconds
float phase = abs( tdate - newmoonref) / (double)2551442.82048;
phase -= (int)phase; // leave only the remainder
if (newmoonref > tdate)
phase = 1 - phase;
return phase;
void displayError(String str)
// show error on display
neopixel.setPixelColor(0, neopixel.Color(7, 0, 0));
neopixel.show();
Serial.println(str);
gfx.setTextColor(EPD_BLACK);
gfx.powerUp();
gfx.clearBuffer();
gfx.setTextWrap(true);
gfx.setCursor(10, 60);
gfx.setFont(&FreeSans12pt7b);
gfx.print(str);
gfx.display();
neopixel.show();
void displayHeading(OpenWeatherMapCurrentData &owcdata)
time_t local = owcdata.observationTime + owcdata.timezone;
struct tm *timeinfo = gmtime(&local);
char datestr[80];
// date
//strftime(datestr,80,"%a, %d %b %Y",timeinfo);
strftime(datestr, 80, "%a, %b %d", timeinfo);
gfx.setFont(&FreeSans18pt7b);
gfx.setCursor((gfx.width() - getStringLength(datestr)) / 2, 30);
gfx.print(datestr);
// city
strftime(datestr, 80, "%A", timeinfo);
gfx.setFont(&FreeSansBold12pt7b);
gfx.setCursor((gfx.width() - getStringLength(owcdata.cityName)) / 2, 60);
gfx.print(owcdata.cityName);
void displayForecastDays(OpenWeatherMapCurrentData &owcdata, OpenWeatherMapForecastData owfdata[], int count = 3)
for (int i = 0; i < count; i++)
// day
time_t local = owfdata[i].observationTime + owcdata.timezone;
char strbuff[80];
strftime(strbuff, 80, "%I", timeinfo);
String datestr = String(atoi(strbuff));
strftime(strbuff, 80, "%p", timeinfo);
// convert AM/PM to lowercase
strbuff[0] = tolower(strbuff[0]);
strbuff[1] = tolower(strbuff[1]);
datestr = datestr + " " + String(strbuff);
gfx.setFont(&FreeSans9pt7b);
gfx.setCursor(i * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(datestr)) / 2, 94);
gfx.print(datestr);
// weather icon
String wicon = owclient.getMeteoconIcon(owfdata[i].icon);
gfx.setFont(&meteocons20pt7b);
gfx.setCursor(i * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(wicon)) / 2, 134);
gfx.print(wicon);
// weather main description
gfx.setCursor(i * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(owfdata[i].main)) / 2, 154);
gfx.print(owfdata[i].main);
// temperature
int itemp = (int)(owfdata[i].temp + .5);
int color = EPD_BLACK;
if ((OWM_METRIC && itemp >= METRIC_HOT) || (!OWM_METRIC && itemp >= ENGLISH_HOT))
color = EPD_RED;
gfx.setTextColor(color);
gfx.setCursor(i * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(String(itemp))) / 2, 172);
gfx.print(itemp);
gfx.drawCircle(i * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(String(itemp))) / 2 + getStringLength(String(itemp)) + 6, 163, 3, color);
gfx.drawCircle(i * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(String(itemp))) / 2 + getStringLength(String(itemp)) + 6, 163, 2, color);
void displayForecast(OpenWeatherMapCurrentData &owcdata, OpenWeatherMapForecastData owfdata[], int count = 3)
gfx.powerUp();
gfx.clearBuffer();
neopixel.setPixelColor(0, neopixel.Color(0, 7, 0));
neopixel.show();
displayHeading(owcdata);
displayForecastDays(owcdata, owfdata, count);
gfx.display();
gfx.powerDown();
neopixel.show();
void displayAllWeather(OpenWeatherMapCurrentData &owcdata, OpenWeatherMapForecastData owfdata[], int count = 3)
gfx.powerUp();
gfx.clearBuffer();
neopixel.show();
// date string
char datestr[80];
// date
strftime(datestr, 80, "%a, %b %d %Y", timeinfo);
gfx.setCursor((gfx.width() - getStringLength(datestr)) / 2, 14);
gfx.print(datestr);
// weather icon
String wicon = owclient.getMeteoconIcon(owcdata.icon);
gfx.setFont(&meteocons24pt7b);
gfx.setCursor((gfx.width() / 3 - getStringLength(wicon)) / 2, 56);
gfx.print(wicon);
gfx.setCursor((gfx.width() / 3 - getStringLength(owcdata.main)) / 2, 72);
gfx.print(owcdata.main);
// temperature
gfx.setFont(&FreeSansBold24pt7b);
int itemp = owcdata.temp + .5;
if ((OWM_METRIC && (int)itemp >= METRIC_HOT) || (!OWM_METRIC && (int)itemp >= ENGLISH_HOT))
color = EPD_RED;
gfx.setCursor(gfx.width() / 3 + (gfx.width() / 3 - getStringLength(String(itemp))) / 2, 58);
gfx.print(itemp);
// draw temperature degree as a circle (not available as font character
gfx.drawCircle(gfx.width() / 3 + (gfx.width() / 3 + getStringLength(String(itemp))) / 2 + 8, 58 - 30, 4, color);
gfx.drawCircle(gfx.width() / 3 + (gfx.width() / 3 + getStringLength(String(itemp))) / 2 + 8, 58 - 30, 3, color);
// draw moon
// draw Moon Phase
float moonphase = getMoonPhase(owcdata.observationTime);
int moonage = 29.5305882 * moonphase;
//Serial.println("moon age: " + String(moonage));
// convert to appropriate icon
String moonstr = String((char)((int)'A' + (int)(moonage * 25. / 30)));
gfx.setFont(&moon_phases20pt7b);
// font lines look a little thin at this size, drawing it a few times to thicken the lines
gfx.setCursor(2 * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(moonstr)) / 2, 56);
gfx.print(moonstr);
gfx.setCursor(2 * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(moonstr)) / 2 + 1, 56);
gfx.print(moonstr);
gfx.setCursor(2 * gfx.width() / 3 + (gfx.width() / 3 - getStringLength(moonstr)) / 2, 56 - 1);
gfx.print(moonstr);
// draw moon phase name
int currentphase = moonphase * 28. + .5;
gfx.setFont(); // system font (smallest available)
gfx.setCursor(2 * gfx.width() / 3 + max(0, (gfx.width() / 3 - getStringLength(moonphasenames[currentphase])) / 2), 62);
gfx.print(moonphasenames[currentphase]);
gfx.display();
gfx.powerDown();
neopixel.show();
void displayCurrentConditions(OpenWeatherMapCurrentData &owcdata)
gfx.powerUp();
gfx.clearBuffer();
neopixel.show();
// weather icon
gfx.setFont(&meteocons48pt7b);
gfx.setCursor((gfx.width() / 2 - getStringLength(wicon)) / 2, 156);
gfx.print(wicon);
gfx.setCursor(gfx.width() / 2 + (gfx.width() / 2 - getStringLength(owcdata.main)) / 2, 160);
// temperature
color = EPD_RED;
gfx.setCursor(gfx.width() / 2 + (gfx.width() / 2 - getStringLength(String(itemp))) / 2, 130);
gfx.print(itemp);
gfx.drawCircle(gfx.width() / 2 + (gfx.width() / 2 + getStringLength(String(itemp))) / 2 + 10, 130 - 26, 4, color);
gfx.drawCircle(gfx.width() / 2 + (gfx.width() / 2 + getStringLength(String(itemp))) / 2 + 10, 130 - 26, 3, color);
gfx.display();
gfx.powerDown();
neopixel.show();
void displaySunMoon(OpenWeatherMapCurrentData &owcdata)
gfx.powerUp();
gfx.clearBuffer();
neopixel.show();
// draw Moon Phase
gfx.setFont(&moon_phases36pt7b);
gfx.setCursor((gfx.width() / 3 - getStringLength(moonstr)) / 2, 140);
gfx.print(moonstr);
gfx.setCursor(gfx.width() / 3 + max(0, (gfx.width() * 2 / 3 - getStringLength(moonphasenames[currentphase])) / 2), 110);
// draw sunrise/sunset
// sunrise/sunset times
// sunrise
time_t local = owcdata.sunrise + owcdata.timezone + 30; // round to nearest minute
char strbuff[80];
strftime(strbuff, 80, ":%M %p", timeinfo);
datestr = datestr + String(strbuff) + " - ";
// sunset
local = owcdata.sunset + owcdata.timezone + 30; // round to nearest minute
datestr = datestr + String(atoi(strbuff));
datestr = datestr + String(strbuff);
int datestrlen = getStringLength(datestr);
int xpos = (gfx.width() - datestrlen) / 2;
gfx.setCursor(xpos, 166);
gfx.print(datestr);
// draw sunrise icon
// sun icon is "B"
String wicon = "B";
gfx.setFont(&meteocons16pt7b);
gfx.setCursor(xpos - getStringLength(wicon) - 12, 174);
gfx.print(wicon);
// draw sunset icon
// sunset icon is "A"
wicon = "A";
gfx.setCursor(xpos + datestrlen + 12, 174);
gfx.print(wicon);
gfx.display();
gfx.powerDown();
neopixel.show();
neopixel.begin();
neopixel.show();
gfx.begin();
Serial.println("ePaper display initialized");
gfx.setRotation(2);
gfx.setTextWrap(false);
Serial.println("Initializing WDT");
wdtInit(); // enable WDT
char data[4000];
static uint32_t timer = millis();
static uint8_t lastbutton = 1;
static bool firsttime = true;
int button = readButtons();
wdtClear();
// update weather data at specified interval or when button 4 is pressed
if ((millis() >= (timer + 1000 * 60 * UPDATE_INTERVAL)) || (button == 4) || firsttime)
Serial.println("getting weather data");
firsttime = false;
timer = millis();
int retry = 6;
while (!wifi_connect())
wdtClear();
delay(5000);
retry--;
if (retry < 0)
displayError("Can not connect to WiFi, press reset to restart");
reboot();
while (1);
String urlc = owclient.buildUrlCurrent(OWM_KEY, OWM_LOCATION);
Serial.println(urlc);
retry = 6;
do
retry--;
wget(urlc, 80, data);
if (strlen(data) == 0 && retry < 0)
displayError("Can not get weather data, press reset to restart");
reboot();
while (1);
while (strlen(data) == 0);
Serial.println("data retrieved:");
Serial.println(data);
retry = 6;
while (!owclient.updateCurrent(owcdata, data))
wdtClear();
retry--;
if (retry < 0)
displayError(owclient.getError());
reboot();
while (1);
delay(5000);
String urlf = owclient.buildUrlForecast(OWM_KEY, OWM_LOCATION);
Serial.println(urlf);
wget(urlf, 80, data);
if (!owclient.updateForecast(owfdata[0], data, 0))
reboot();
while (1);
if (!owclient.updateForecast(owfdata[1], data, 2))
reboot();
while (1);
if (!owclient.updateForecast(owfdata[2], data, 4))
reboot();
while (1);
switch (lastbutton)
case 1:
displayAllWeather(owcdata, owfdata, 3);
break;
case 2:
displayCurrentConditions(owcdata);
break;
case 3:
displaySunMoon(owcdata);
break;
if (button == 0) {
return;
Serial.print("Button "); Serial.print(button); Serial.println(" pressed");
if (button == 1) {
lastbutton = button;
if (button == 2) {
//displayForecast(owcdata,owfdata,3);
if (button == 3) {
// wait until button is released
while (readButtons()) {
delay(10);
Serial shows it reaching "Connecting to WiFi..." before rebooting.
I put 'wdtClear();' in every loop with a delay that I found, in the main loop, and in the wifi connection function. I'll keep looking over ti to see if I missed something, but I'm leaning towards it not working with a wifi connection due to times involved.
