UART with Circuit Playground Bluefruit & Connect App without
Play with it! Please tell us which board you're using.
romano47
Post by romano47 »
I'm new to the Bluefruit Connect App, and am wondering whether it's even possible to connect to the CP Bluefruit via UART without opening the serial monitor first?
I'd like to be able to plug (and unplug) the device from an outlet without having to reconnect to my laptop. Would be great to know if there are any workarounds, alternate solutions, OR whether this is just par for the course.
mikeysklar
Re: UART with Circuit Playground Bluefruit & Connect App wit
Post by mikeysklar »
You should be able to use the CP Bluefruit without a mandatory console, but you might need to modify the code. There is often a wait for serial loop that looks like this on the Arduino side:
  while (! Serial); // Wait untilSerial is ready - Leonardo
  Serial.println("Enter LED Number 0 to 7 or 'x' to clear");
You would need to comment out the while(!Serial) line.
Which code example have you been using or if you like paste in the code that you have been using here.
romano47
Post by romano47 »
Gah, so easy. Thank you (and, I should have scrutinized the code more before posting). This worked perfectly.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
