Disable Speaker but keep audio signal on A0 in Makecode
Play with it! Please tell us which board you're using.
nposenr
Post by nposenr »
Hi All,
I am working on a project which involves using an external speaker. The code has to be in makecode as this is part of a larger workshop. What I am trying to do is disable the onboard speaker (via code) while still maintaining the signal output on pin A0. I can currently achieve this by shorting the right most flash access pin (pin 11) to ground but really need to do this in software. I am not sure I need if I can write a custom Makecode block to do this. Any help on this front would be appreciated.
mikeysklar
Re: Disable Speaker but keep audio signal on A0 in Makecode
Post by mikeysklar »
Are you using a Circuit Playground Express board or another model?
This could only be for micro:bit, but here is how it does there:
https://makecode.microbit.org/reference ... er-enabled
nposenr
Post by nposenr »
I am using a Circuit Playground Express and cannot change to microbit. That is the exact functionality that I want but that block is not available for the CPX. I am also un able to track down the equivalent music.setBuiltInSpeakerEnabled(false) Javascript method for the CPX to write my own custom block even though PIN_SPEAKER_AMP = DAL.PA30; is defined in the CPX config.
mikeysklar
There is a:
set volume <value>
which defaults to 128 and you could reduce to 0. Hardly ideal, but though I would mention that option.
There was an issue opened with the pxt-adafruit github repo. Someone was trying to do the same as you and disable the speaker and the PA30 AMP pin setting came up as well. Unfortunately, there is a MUX involved that makes turning off the internal speaker AMP more difficult than just pulling PA30 low.
https://github.com/Microsoft/pxt-adafruit/issues/138
nposenr
Post by nposenr »
Thanks for the feedback. the github post is interesting. Sadly setting volume to 0 does not work as it also sets the volume coming off of pin 0 and therefore we get no signal. The current solution that we are running is a piece of copper tape from the pad on the the back of the CPX to the ground pin. We may just have to stick with that.
mikeysklar
You might have to stick with the copper tape. You can also open a new issue if you like requesting an enhancement.
https://github.com/microsoft/pxt-adafruit/issues
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
