What is the exact type of 2-pin JST PH Connector?
There are soooo many different ones.
I'm looking for a number like
SPH-002T-P0.5S
SPH-002T-P0.5S
That's for the "female" contact, right? The "male" board-side connectors are always the same?The choice of contact depends on the wire gauge you are using.
There are surface mount and through hole versions. Dimensions are shown in the datasheet: https://cdn.shopify.com/s/files/1/0227/ ... 1642424638The "male" board-side connectors are always the same?
