Playground on chromebooks
Play with it!
Post Reply
kimgaylordagc
Post by kimgaylordagc »
1. can I run playgrounds on chromebooks, through what software if so
2. does code.org still support work on playgrounds
3. is there anyone I can actually talk to about playgrounds
When I download the program on my windows laptop and plugged in the playground it does not show the drive to open up the program to try to run it and I also want to use the playground on a chromebook and need to know if that is possible or not
mikeysklar
Re: Playground on chromebooks
Post by mikeysklar »
Are you trying to use a Circuit Playground Express board with your Chromebook (and Windows machine mentioned)?
If so, there is a guide for getting started with a Circuit Playground Express and Chromebooks:
https://learn.adafruit.com/using-circui ... book-setup
The way your post read it sounds as if you are trying to use an app called playgrounds which I'm not familiar with.
Post Reply
Return to “Circuit Playground and Circuit Playground Express”
