Fona 3G dos not work corektly with liberary
mafofpv
Post by mafofpv »
i have a arduino pro mini 3,3V 8mhz. everything else works normal. i have sent sms to my phone. but the post command in the liberary dosent work. i have norrowed it down to one line in the code. this : fona.HTTP_POST_start(url, F("text/plain"), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length)
to be clear i am using the code provided på adafruit. in the adafruit fona liberary you have the test program. here i send W to the arduino and everything works so far. i have later added Serial.print to narow it down to that spesefic line. in the serial monitor this comes out:
loop bygner
FONA
delay ferdig
http://desk-webs-sink-193-90-75-150.loca.lt/in
---> AT+HTTPTERM
<--- ERROR
---> AT+HTTPINIT
<--- ERROR
Error
anny tips?
[The extension ino has been deactivated and can no longer be displayed.]
