Hi all,
I am using the MatrixPortal M4 to drive an LED panel that displays scrolling text. I need to be making GET requests while the text is scrolling. Currently, the adafruit_request.get() function is blocking and the scrolling feature of my code gets delayed until the request completes. Is there any way to to make the request non-blocking and simultaneously carry out the request while the matrix panel is still scrolling?
I figured since there is a completely separate ESP32 with the sole job of carrying out requests there should be a way to let the SAMD continue to drive the matrix while the request is being carried out on the ESP.
Any insight into potential approaches to finding a solution for my issue would be greatly appreciated. If this is something that would simply not be possible to do, pointing that out would be helpful too.
I was originally thinking the async library, but have not had much luck implementing something that meets my needs so far.
Matrix Portal M4 Circuitpython non blocking requests
- lmurdock12
- mikeysklar
Re: Matrix Portal M4 Circuitpython non blocking requests
This discussion has come up before in the Adafruit_CircuitPython_Requests github repo (closed issue).
https://github.com/adafruit/Adafruit_Ci ... /issues/69
You have the right idea. Get passed non-blocking with an async library.
