The board resets with the following when the line "cameraFeed->save(encrypt)" is executed:
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13516
load:0x40080400,len:3604
entry 0x400805f0
If I grab the value of "encrypt" and upload it to the feed data via the API (https://io.adafruit.com/api/v2/<myUsern ... key=<myKey>) the image saves and displays fine so I am certain the base64 value is ok.
Hopefully I have just done something stupid in my code and one of you awesome gurus out there can steer me right.
Here's my code:
#include "config.h"
#include "esp_camera.h"
#include "base64.h"
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 21
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 19
#define Y4_GPIO_NUM 18
#define Y3_GPIO_NUM 5
#define Y2_GPIO_NUM 4
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
unsigned long lastUpdate;
camera_config_t config;
AdafruitIO_Feed *cameraFeed = io.feed("camera");
Serial.begin(115200);
Serial.setDebugOutput(true);
Serial.println();
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
delay(1000);
ESP.restart();
} else {
Serial.println("Camera configuration complete!");
sensor_t * s = esp_camera_sensor_get();
s->set_framesize(s, FRAMESIZE_CIF); // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
Serial.print("Connecting to Adafruit IO");
io.connect();
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
Serial.println();
Serial.println(io.statusText());
log_d("Total heap: %d", ESP.getHeapSize());
log_d("Free heap: %d", ESP.getFreeHeap());
log_d("Total PSRAM: %d", ESP.getPsramSize());
log_d("Free PSRAM: %d", ESP.getFreePsram());
io.run();
if (millis() > (lastUpdate + 5000)) {
camera_fb_t *fb = NULL;
fb = esp_camera_fb_get();
if (fb != NULL) {
String encrypt = base64::encode(fb->buf, fb->len);
esp_camera_fb_return(fb);
Serial.println(encrypt);
cameraFeed->save(encrypt);
} else {
Serial.println("Camera Error");
lastUpdate = millis();
