Can I use a M0 for this?
magoogle
Post by magoogle »
I want to take a switch that provides resistance values depending on position and have it perform an action based on those values.
The switches values are as such: Down is 47Ω to ground, Up is 307Ω to ground. No switch pressed is 10kΩ to ground.
The action would be to control a forward/reverse relay module that is 3 wires. FWD/GND/REV. Model: F-1020 12v, Specs: Operating Voltage 10 - 15v DC, Switch Short current 30mA @ 12V
Will the M0 handle this? If not, is there another tiny controller that could?
dastels
Re: Can I use a M0 for this?
Post by dastels »
Any microcontroller will be able to do this with the right additional circuitry. You would add a pullup resistor to Vcc to turn those switch resistances into a variable voltage divider, then read the voltage at the point between the pullup and the switch using an analog input. The relay would need a drive for each of FWD and REV. A transistor and shunt diode for each will probably suffice. See https://learn.adafruit.com/transistors- ... rs-2998941.
XRAD
Post by XRAD »
Yes, you can read the resistance in your code and 'do' something with it....That's how you can get multiple functions off one pin, like stereo control steering wheel buttons in a car...just have to read the pin for state changes....
classic example: rotary resistance switch with 'x number of' positions....
another way is by 'timing' the button press...ex: 1 second is forward, 2 sec is reverse...ect....
