dafruit_NeoPixel and SD card reading
scharpfwj
Post by scharpfwj »
I am new to the Arduino and its programing. I am trying to control a string of LEDs (WS2811) with an Arduino(UNO R3). The pattern I am trying to generate is complex and I was hoping to have it stored on a SD card. I was hoping to read the SD card and use the data to determine the LED pattern. Reading data from the SD card works fine. Controlling the LEDS works fine. I can control up to 550 LEDs with no issue. However when I try to do both in the same program, I run into a problem. The "Adafruit_NeoPixel pixels()" command causes problems with the SD.open() command:
The command:
Adafruit_NeoPixel pixels(100, PIN, NEO_GRB + NEO_KHZ800);
Works fine. I can open the data file.
The command:
Adafruit_NeoPixel pixels(150, PIN, NEO_GRB + NEO_KHZ800);
executes. However it will NOT open the data file. I get "myFile" = 0.
any suggestions?
// For SD card reading
#include <SPI.h>
#include <SD.h>
#define SDPIN     10 // pin for reading data from the SD card
File myFile;  // I am not sure what this does
// For LED cntrol
#define PIN        6 // Pin the commands the LEDs
#define NLEDs  100 // Number of LEDs
// for reading the data file
#define FNAME  "LEDs150.txt"
// adafruit lib led control
  Adafruit_NeoPixel pixels(NLEDs, PIN, NEO_GRB + NEO_KHZ800);
  pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
 if (!SD.begin(SDPIN)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
 // open the file for reading:
  myFile = SD.open(FNAME);
  Serial.println(myFile);
  if (myFile) {
    Serial.println(FNAME);
  // close the file:
  myFile.close();
dastels
Re: dafruit_NeoPixel and SD card reading
Post by dastels »
Sounds like a memory limitation issue. The UNO has a very small amount of RAM. If you want a lot of pixels and the SD you'll need a MCU board with more memory.
scharpfwj
Post by scharpfwj »
Would an Arduino DUE work?
dastels
Post by dastels »
Definitely. I'm not familiar with how the SRAM banks works but you'll have at least 16 times more of it.
