Installation issue RPLidar A1
pmgrue
Post by pmgrue »
I am attempting to install the software for the RPLidar unit. I am using V1 Buster on a Raspberry Pi 4B 8GB and enter the command
pip install Adafruit_CircuitPython_RPLIDAR
as per the adafruit instructions but unfortunately it does not work. What do I need to do to get it working?
The following message shows up: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-58nrga/Adafruit-CircuitPython-RPLIDAR/
Here is the entire output:
Using cached https://files.pythonhosted.org/packages ... 2.7.tar.gz
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
File "/tmp/pip-install-58nrga/Adafruit-CircuitPython-RPLIDAR/setup.py", line 54, in <module>
py_modules=["adafruit_rplidar"],
File "/usr/lib/python2.7/dist-packages/setuptools/__init__.py", line 144, in setup
_install_setup_requires(attrs)
File "/usr/lib/python2.7/dist-packages/setuptools/__init__.py", line 139, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 724, in fetch_build_eggs
replace_conflicting=True,
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 782, in resolve
replace_conflicting=replace_conflicting
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1065, in best_match
return self.obtain(req, installer)
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1077, in obtain
return installer(requirement)
File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 791, in fetch_build_egg
return cmd.easy_install(req)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 704, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 730, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 915, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1183, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1169, in run_setup
run_setup(setup_script, args)
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 253, in run_setup
raise
File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
yield
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 250, in run_setup
_execfile(setup_script, ns)
File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 44, in _execfile
code = compile(script, filename, 'exec')
File "/tmp/easy_install-n8O_QX/setuptools_scm-7.0.5/setup.py", line 20
def scm_version() -> str:
SyntaxError: invalid syntax
adafruit_support_carter
Re: Installation issue RPLidar A1
"pip" is mapped to the Python 2 version on your setup. Python 2 is deprecated and no longer supported.
To force installing for Python 3, try:
pip3 install adafruit-circuitpython-rplidar
pmgrue
Post by pmgrue »
Thank you very much, I was able to set it up with pip3 as recommended. But now when I run the program that is supplied I receive the error message:
RPLidar Exception: Wrong body size
adafruit_rplidar.py, line 280
No specific suggestions for this error(yet)
pygame and cpython are both installed.
Can you point me in the right direction?
The program you are running is the example from the library?
https://github.com/adafruit/Adafruit_Ci ... pletest.py
pmgrue
Post by pmgrue »
With the code in the attached link it works. Perhaps I was in an old deprecated repository?
Thank you very much!
