Serial port on Metro ESP32-S2 Express
simoniceberg
Post by simoniceberg »
I have been programming for Metro ESP32-S2 Express using ESP-IDF with PlatformIO. Contrary to the other ESP32 board I have (ESP32-DevKitC V4), after uploading the serial port disappears, making it difficult to monitor the output from the chip itself.
I have tried this code snippet:
uart_config_t uart_config = {
        .baud_rate = 115200,
        .data_bits = UART_DATA_8_BITS,
        .parity    = UART_PARITY_DISABLE,
        .stop_bits = UART_STOP_BITS_1,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
int intr_alloc_flags = 0;
QueueHandle_t uart_queue;
ESP_ERROR_CHECK(uart_driver_install(0, 1024, 1024, 10, &uart_queue, intr_alloc_flags));
ESP_ERROR_CHECK(uart_param_config(0, &uart_config));
ESP_ERROR_CHECK(uart_set_pin(0, 1, 3, -1, -1));
in an attempt to reopen the port used for uploading. However it doesn't show up in the monitor.
Thanks,
Simon
mikeysklar
Re: Serial port on Metro ESP32-S2 Express
Post by mikeysklar »
Two common options to get the serial console are:
1) press the reset button on the Metro ESP32-S2 so the code restarts and the device shows back up so you can pickup a console.
2) On the Arduino IDE a work around is to selecrt the USB Mode: Hardware CDC/JTAG from the Tools menu. This is known to work with the ESP32-S3, but I suspect will also work with the ESP32-S2.
https://github.com/espressif/arduino-esp32/issues/6762
Return to “Metro, Metro Express, and Grand Central Boards”
