Blink for Metro M0 using direct register manipulation
MetroM0
Post by MetroM0 »
I am using an Metro M0 with circuitPython loaded onto it.
in Arduino IDE I can perform direct port manupulation as illustrated on this thread:
viewtopic.php?f=57&t=102695&p=514098&hi ... on#p514098
Question:
Is it possible to perform same direct port manipulation using circuitPython Script?
neradoc
Re: Blink for Metro M0 using direct register manipulation
Post by neradoc »
No, there is no direct port manipulation API. That seems really outside of the scope of Circuitpython.
Is there a specific use case you are thinking of that can't be achieve with CP ?
We are always interested in learning about those.
MetroM0
Post by MetroM0 »
neradoc wrote:No, there is no direct port manipulation API. That seems really outside of the scope of Circuitpython.
That's a pity...
I fail to understand how this is 'out of scope' since this can be achived within arduino IDE. I have used direct port manipulation in the past for parallel read/writes and I'm truly surprised that this feature is not available if I were to work with CircuitPython (still beginner with it btw!)
no particular project in mind at the moment but comparing the Metro with the Metro express, it strikes me that 2 pins are not used, namely pins 48 and 22 (used as part for the SPI flash connections for Metro express)
I checked the pins defined for Metro using dir(board) and the above mentioned pins are not listed. so I was wondering if thru direct port manipulation, these could be accessed. Also would have been nice if for the metro the 2nd SPI but define! Extra IOs are always handy and soldering is not and issue for me! ;)
MetroM0
Post by MetroM0 »
Is there any way for me to modify the METRO .uf2 file to allow me to use SP1 and/or SCK pin is #38, MISO is #36, MOSI is #37, and CS is #39 as digital IO pins?
if yes, could you kindly please describe to me how to go about doing that?
neradoc
Post by neradoc »
I am very confused. You say Metro M0, but there is no Metro M0 that is not Express that I know of.
What board are you using exactly ?
What build of Circuitpython are you using ?
Do you mean the Arduino Zero ?
Can you show on the board schematic/pinouts the pins that are not available in Circuitpython ?
If they are missing and usable they can be added to the board definition.
MetroM0
Post by MetroM0 »
neradoc wrote:I am very confused. You say Metro M0, but there is no Metro M0 that is not Express that I know of.
Yes, I am using an arduino M0 pro, Circuitpython build is adafruit-circuitpython-arduino_zero-en_GB-7.3.1.uf2
As previously mention when I run the "dir(board)" command I cannot see the SPI1 definitions ie SCK1 pin#38, MISO1 #36, MOSI1 #37, and CS1 #39
This is the results I get:
['__name__', 'A0', 'A1', 'A2', 'A3', 'A4', 'A5', 'D0', 'D1', 'D10', 'D11', 'D12', 'D13', 'D2', 'D3', 'D4', 'D5', 'D6', 'D7', 'D8', 'D9', 'I2C', 'LED', 'MISO', 'MOSI', 'RX', 'SCK', 'SCL', 'SDA', 'SPI', 'TX', 'UART', 'board_id']
hence my query as to whether this pins can be made accessible within circuitPython. the hadware aspect is not an issue for me.
schem_arduino-M0-pro.pdf
(106.53 KiB) Downloaded 3 times
neradoc
Post by neradoc »
The pins might be available through the microcontroller module.
(I don't have the board, I tested by installing the Arduino Zero build on another M0 board).
>>> import microcontroller
>>>help(microcontroller.pin)
object <module ''> is of type module
  PA02 -- board.A0
  PA03 -- microcontroller.pin.PA03
  PA04 -- board.A3
  PA05 -- board.A4
  PA06 -- board.D8
  PA07 -- board.D9
  PA08 -- board.D4
  PA09 -- board.D3
  PA10 -- board.D1
  PA11 -- board.D0
  PA12 -- board.MISO
  PA13 -- microcontroller.pin.PA13
  PA14 -- board.D2
  PA15 -- board.D5
  PA16 -- board.D11
  PA17 -- board.D13
  PA18 -- board.D10
  PA19 -- board.D12
  PA20 -- board.D6
  PA21 -- board.D7
  PA22 -- board.SDA
  PA23 -- board.SCL
  PA27 -- microcontroller.pin.PA27
  PA28 -- microcontroller.pin.PA28
  PB02 -- board.A5
  PB03 -- microcontroller.pin.PB03
  PB08 -- board.A1
  PB09 -- board.A2
  PB10 -- board.MOSI
  PB11 -- board.SCK
  PB22 -- microcontroller.pin.PB22
  PB23 -- microcontroller.pin.PB23
Are there missing pins from that list ? I don't actually know exactly where the microcontroller module pins are managed, I can look into it.
You can add pin names for the ones that don't have them to the board definition, if they are the same on the zero and the M0 Pro, or we can make a new board definition for the M0 Pro.
https://github.com/adafruit/circuitpyth ... ero/pins.c
The flash pins on the Metro are the following:
#define SPI_FLASH_MOSI_PIN          &pin_PB22
#define SPI_FLASH_MISO_PIN          &pin_PB03
#define SPI_FLASH_SCK_PIN           &pin_PB23
#define SPI_FLASH_CS_PIN            &pin_PA13
MetroM0
Post by MetroM0 »
neradoc wrote: Are there missing pins from that list ? I don't actually know exactly where the microcontroller module pins are managed, I can look into it.
from the list your shared, it does appear that the pins I'm after are defined here...
neradoc wrote: You can add pin names for the ones that don't have them to the board definition, if they are the same on the zero and the M0 Pro, or we can make a new board definition for the M0 Pro
I sure can add them to the board definition file but just to confirm, within CircuitPython, could you kindly please lay out the steps I would need to take in order to confirm I have done so correctly (as mentioned before I am a noob when it comes to using circuitpython! ;P)
neradoc
Post by neradoc »
MetroM0 wrote:from the list your shared, it does appear that the pins I'm after are defined here...
Yeah, so you can use them like you can use board.* pins:
import digitalio
import time
blink = digitalio.DigitalInOut(microcontroller.pin.PB03)
blink.switch_to_output(True)
while True:
    blink.value = not blink.value
    time.sleep(1)
Looking closer at the schematics though:
- PB03 is wired to the LED_RX
- PB22, PB23 and PA13 are wired to the on-board programming chip like they are on the zero
- LED_TX is wired to PA27
So you should be able to use PB03 and PA27 from microcontroller to blink those LEDs. PA17 is board.LED (and D13).
Are there other pins that are not in the board module ?
If so, can you show them on the pinout or schematics ?
MetroM0
Post by MetroM0 »
Thank you for the sample code. I tried it out but is comes up with the following error:
>>> import digitalio
>>> led = digitalio.DigitalInOut(microcontroller.pin.PB03)
  File "<stdin>", line 1, in <module>
ValueError: PB03 in use
Any ideas as to why?
neradoc wrote: Looking closer at the schematics though:
that accounts for all the pins that are not directly accessible of the M0 Pro as far as I am aware, thank you.
The script you shared allows me to use those pins a Digital IO but if I wanted to make use of SPI1 (ie SPI_Flash on Metro express), is there any library I would be able to use to allow me to do that as well?
PS: I am very well pleased with the support I have been receiving here so far! :)
neradoc
Post by neradoc »
MetroM0 wrote:Any ideas as to why?
Oh ok, so the LEDs are always in use to automatically report the serial traffic.
Sorry I missed that, I'm not familiar with that feature and I don't have the board to try stuff.
That wouldn't help you use SPI anyway.
So the conclusion is that there are no free pins on the board that are not already defined it seems.
MetroM0 wrote:The script you shared allows me to use those pins a Digital IO but if I wanted to make use of SPI1 (ie SPI_Flash on Metro express), is there any library I would be able to use to allow me to do that as well?
You can use any valid pins for SPI.
Here is a script that should list all trio of pins valid for SPI, excluding the default SPI pins (D11-D13).
wheresmyspi.py
(1.05 KiB) Downloaded 3 times
MetroM0
Post by MetroM0 »
Too bad this is the case :(
But can live with that! it was a long shot after all! ;)
Thank your for your kind support in understanding my board better.
I consider this topic not closed! :)
MetroM0
Post by MetroM0 »
neradoc wrote: So the conclusion is that there are no free pins on the board that are not already defined it seems.
@neradoc ,
I have been playing around a bit more with my board and turns out that what it is possible to use the 'extra' pins though not all of them!!
  PA02 -- board.A0
  PA03 -- microcontroller.pin.PA03 -- AREF on board can be used a digital IO
  PA04 -- board.A3
  PA05 -- board.A4
  PA06 -- board.D8
  PA07 -- board.D9
  PA08 -- board.D4
  PA09 -- board.D3
  PA10 -- board.D1
  PA11 -- board.D0
  PA12 -- board.MISO
  PA13 -- microcontroller.pin.PA13 -- Available to use
  PA14 -- board.D2
  PA15 -- board.D5
  PA16 -- board.D11
  PA17 -- board.D13
  PA18 -- board.D10
  PA19 -- board.D12
  PA20 -- board.D6
  PA21 -- board.D7
  PA22 -- board.SDA
  PA23 -- board.SCL
  PA27 -- microcontroller.pin.PA27 -- NOT available
  PA28 -- microcontroller.pin.PA28 -- Available to use (controls 5V supply from USB)
  PB02 -- board.A5
  PB03 -- microcontroller.pin.PB03 -- NOT available
  PB08 -- board.A1
  PB09 -- board.A2
  PB10 -- board.MOSI
  PB11 -- board.SCK
  PB22 -- microcontroller.pin.PB22 -- Available to use
  PB23 -- microcontroller.pin.PB23 -- Available to use
I do have a couple of follow-up questions though:
1. I am able to use PA28 as digital IO but looking at the board schematic I'm unclear of its acutal purpose. is it really OK to use this pin as digital IO?
2. PB22/PB23 has Serial UART capability (wired up as such based on schematic). while I was able to use them as digital IO, if I wanted to use them as UART within circuitPython, would it be possible?
Would it also be possible to share a script to demostrate the use of the board hardware serial port UART (ie board pins 0 and 1) please?
Return to “Metro, Metro Express, and Grand Central Boards”
