I have a sketch running that will not allow another USB download, so the machine (metro-mini) is locked up.
Reset appears to work, but the sketch just resumes with no sync on download attempts.
Is there some other way to clear the memory or disrupt the executing code????
run-away sketch
- adafruit_support_carter
Re: run-away sketch
Try this general process and see if it helps:
https://learn.adafruit.com/adafruit-fea ... aq-2704880
