Specs on TTL Serial JPEG Camera (Product ID 397)
Post Reply
tyamaguchi
Post by tyamaguchi »
Not sure if this is the right spot to ask this question, but I need to know some specs about this camera (Specs on TTL Serial JPEG Camera - Product ID 397) that I can't seem to find on the datasheet. The camera lens looks like it's threaded and screwed in; is the lens removable/can it be replaced with a different lens? If so, what are the dimensions of the hole? Additionally, does Adafruit have any camera modules with IR lenses? Thanks!
Re: Specs on TTL Serial JPEG Camera (Product ID 397)
The camera takes standard 12mm threaded lenses. It is IR sensitive out-of-the-box as described in the FAQ:
https://learn.adafruit.com/ttl-serial-c ... aq-2946818
tyamaguchi
Thank you so much for your reply! What is the field of view of the lens that's in the box?
About 60 degrees.
Post Reply
