LED Glasses Driver uF2 loader
- afp316
I recently received my led glasses driver nRF52840. I've plugged the board into my computer via the usb-c to usb-c connector and via my usb-c to usb-a (known good) connecter with the board switch on but the computer doesn't recognize. I've double clicked the reset button at various intervals with no success. When I plug in the CHG led is dimly lit. The board has not been modified from as-arrived. Is there a special driver I need to install?
- dastels
Re: LED Glasses Driver uF2 loader
What OS are you running? Have you verified that the cable(s) are data cables and not power/charge? More info on the bootloader is at https://learn.adafruit.com/adafruit-met ... er-details.
- afp316
I'm running Windows 11. I have verified the cables as data cables based on using them on other ada boards I have.
I will check out the guide to see if I'm missing something.
- dastels
Win 11 shouldn't need any additional drivers. Data cables,check.
