ESP32-S2 Feather failing to complete WipperSnapper firmware
adafruit.io wippersnapper BETA support, discussions, and more!
snowbud
Post by snowbud »
I believe that this is the same or similar problem reported by mbd here: viewtopic.php?f=66&t=193568
I'm following these instructions - https://io.adafruit.com/wippersnapper/new and failing at step 8, which appears to be the Provisioning phase.
I've tried a number of things in roughly this order:
  • Performed another Factory Reset and Bootloader Repair, and WipperSnapper version 42 install
  • Regenerated API key and updated secrets.json
After each install of WipperSnapper, the device blinks yellow and then eventually has a solid yellow light. After a little while, it must reboot as the light goes out and it starts over again, blinking yellow and then eventually a solid yellow light, and then reboots...
brubell
Learn User Page
Re: ESP32-S2 Feather failing to complete WipperSnapper firmware
Post by brubell »
Could you please file this as an issue on GitHub: https://github.com/adafruit/Adafruit_Wi ... new/choose
I'll be able to work on replicating and fixing it from there.
snowbud
Post by snowbud »
Thank you for the reply @brubell
I've created the issue on Github
snowbud
Post by snowbud »
Thanks to another post viewtopic.php?p=937390#p937390, I was able to get the device connected.
The WiFi network that I was attempting to connect to had both 2.4 and 5 Ghz WiFi bands enabled. Using the CircuitPython Internet Test https://learn.adafruit.com/adafruit-esp ... ernet-test article, I was able to verify the device wouldn't connect to this network. I created a new network that only had the 2.4Ghz WiFi band enabled and was able to connect.
When updating the secrets.json file with this new, 2.4Ghz ONLY network, I was able to connect to Adafruit IO using the WipperSnapper firmware!
Step 8 of the Adafruit IO Add new device walkthrough/article indicates that a flashing or solid yellow light indicates that the device is in the Provisioning state. But, I suspect that it's actually in the WiFi connection stage.
brubell
Learn User Page
Post by brubell »
Thanks for details on the resolution, glad you were able to connect. We're going to look at how to signal to users that they need a 2.4GHz (only) network in order to connect to AIO using WipperSnapper.
We'll also take a look at step 8 as mentioned above.
snowbud
Post by snowbud »
I believe most routers nowadays have both 2.4 and 5 Ghz enabled by default. Wonder if it's just some routers that cause issues? Otherwise I would expect lots of other people having issues.
If it's helpful for troubleshooting / duplicating the issue, I'm using Google Nest mesh WiFi
Return to “Adafruit IO Wippersnapper Beta”
