NeoPixel Ring - 24 x 5050 RGB LED with Integrated Drivers
- jiazhangwang
Hi, there are two +5v and GND ports on the NeoPixel Ring - 24 x 5050 RGB LED with Integrated Drivers. They are the same? We just need to use one of them?
- michaelmeissner
Re: NeoPixel Ring - 24 x 5050 RGB LED with Integrated Drivers
The +5 and GND ports are the same. Having two ports makes it easier to have one set of cables that provide the data in, power, and ground from your microprocessor and to have a second set of cables that provide data out, power, and ground. Otherwise, you would need to make a Y-cable if you were going to connect the neopixels in series.
- rooppoorali
All +5V and GND pins are the same.
- adafruit_support_carter
yepThey are the same?
yepWe just need to use one of them?
Tons more info, including schematics, in the uberguide:
https://learn.adafruit.com/adafruit-neo ... -neopixels
