I2C on Metro Mini (pullup resistor and IS31FL3237 LED Driver)
Post Reply
project zero
Post by project zero »
Hi there,
I am using the metro mini and attempting to talk to the IS31FL3237 LED Driver. It should be pretty straightforward - they have sample Arduino code, etc.
But I'm a bit concerned about whether I need a pullup resistor or not. According to the Wire Library, a pullup resistor is required, but it doesn't give much detail, and examples that it references appear to be missing.
So I have two questions:
1. Does anyone know if I should need a pullu=up resistor, particularly to talk to the IS31FL3237 LED Driver?
2. Does anyone have experience with the LED Driver? The LEDs are wired up on a nice board off the shelf, I'm really hoping comms will be quick and easy (in a perfect world).
Thanks! I have pasted the arduino sample code for the LED driver below.
#include<Wire.h>
#include<avr/pgmspace.h>
#define Addr_GND 0x68
//7 bit format is 0x3F
byte PWM_Gamma64[64]=
  0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,
  0x08,0x09,0x0b,0x0d,0x0f,0x11,0x13,0x16,
  0x1a,0x1c,0x1d,0x1f,0x22,0x25,0x28,0x2e,
  0x34,0x38,0x3c,0x40,0x44,0x48,0x4b,0x4f,
  0x55,0x5a,0x5f,0x64,0x69,0x6d,0x72,0x77,
  0x7d,0x80,0x88,0x8d,0x94,0x9a,0xa0,0xa7,
  0xac,0xb0,0xb9,0xbf,0xc6,0xcb,0xcf,0xd6,
  0xe1,0xe9,0xed,0xf1,0xf6,0xfa,0xfe,0xff
  // put your setup code here, to run once:
  Wire.begin();
  Wire.setClock(400000);//I2C 400kHz
//  pinMode(4,OUTPUT);//SDB
//  digitalWrite(4,HIGH);//SDB_HIGH
  Init_FL3237();
  // put your main code here, to run repeatedly:
   IS31FL3237_mode1();//breath mode
void IS_IIC_WriteByte(uint8_t Dev_Add,uint8_t Reg_Add,uint8_t Reg_Dat)
  Wire.beginTransmission(Dev_Add/2);
  Wire.write(Reg_Add); // sends regaddress
  Wire.write(Reg_Dat); // sends regaddress
  Wire.endTransmission(); // stop transmitting
void Init_FL3237(void)
  uint8_t i = 0;
  for(i=0x4A;i<=0x6D;i++)
    IS_IIC_WriteByte(Addr_GND,i,0xff);//turn on all LED
   for(i=0x01;i<=0x48;i++)
    IS_IIC_WriteByte(Addr_GND,i,0x00);//write all PWM set 0x00
  IS_IIC_WriteByte(Addr_GND,0x49,0x00);//update PWM & congtrol registers
  IS_IIC_WriteByte(Addr_GND,0x6E,0xFF);//Global current
  IS_IIC_WriteByte(Addr_GND,0x00,0x01);//normal operation and 8bit PWM
void IS31FL3237_mode1(void)//white LED
  int8_t i = 0;
  int8_t j = 0;
  for(i=1;i<=24;i+=2)//R LED running
    IS_IIC_WriteByte(Addr_GND,(i*3),0xFF);//set  PWM
    delay(80);//100ms
  delay(500); //keep 0.5s
  for(i=23;i>0;i-=2)//G LED running
    IS_IIC_WriteByte(Addr_GND,(i*3-2),0xFF);//set  PWM
    delay(80);//100ms
  for(i=1;i<=24;i+=2)//B LED running
    IS_IIC_WriteByte(Addr_GND,(i*3+2),0xFF);//set  PWM
    delay(80);//100ms
   for (j=63;j>=0;j--)//all LED breath falling
     for(i=1;i<=0x48;i+=2)
      IS_IIC_WriteByte(Addr_GND,i,PWM_Gamma64[j]);//set all PWM
    delay(30);//20ms
  delay(500); //keep o 0.5s
adafruit_support_carter
Re: I2C on Metro Mini (pullup resistor and IS31FL3237 LED Driver)
Pull up resistors are a requirement of the I2C bus:
https://learn.adafruit.com/working-with ... -resistors
The Metro Mini does not include those.
project zero
Carter, thank you very much. I will pull up SDA and SCL to 5V. Is it acceptable for me to use the 5V OUT on my Metro Mini? And secondly, what resistor size do you recommend?
Lastly, is it acceptable to set a pinout or 2 to digital High and then connect the sda and scl lines to them, with resistors?
Post Reply
Return to “Metro and Metro Express, Grand Central”
