Wippersnapper updates not working
adafruit.io wippersnapper BETA support, discussions, and more!
Post Reply
ALB1985
Post by ALB1985 »
Hello, I was wondering if there is something wrong with the Wippersnapper updates for the Magtag only get yellow LEDS on the board after the update. I also tried this on a ESP32-S2 Feather and it does the same thing with its version of Wippersnapper.
mikeysklar
Re: Wippersnapper updates not working
Post by mikeysklar »
beta43 and beta44 were released 4-days ago. Which are you running?
https://github.com/adafruit/Adafruit_Wi ... duino/tags
Do you want to confirm things are working with beta42?
snowbud
Post by snowbud »
I had an issue with the yellow light flashing, and then a solid yellow light during the initial install of the wippersnapper firmware on an ESP32-S2.
I believe it was because the WiFi network I was attempting to connect to had the same SSID (wireless network name) for both the 2.4 and 5 Ghz band. I created a new 2.4 Ghz only WiFi network, and then used this during the setup and was successful.
ALB1985
Post by ALB1985 »
Hello, Sorry I misunderstood. Im running Beta 44 but I did not have the secrets file replaced, I didn't realize it gets deleted on updates. I was able to get it working editing the file in Notepad ++. Thanks and sorry for the confusion.
brubell
Post by brubell »
It shouldn't have been fully deleted during updates. Did it have the default values in it?
Post Reply
Return to “Adafruit IO Wippersnapper Beta”
