Wiring SPW2430
Post Reply
FailingTinkerer
Wiring SPW2430
Post by FailingTinkerer »
Hi everyone,
This is my first time wiring up this sensor and it seems simple enough. But... I have no clue what to do with the AC or DC output.
I thought connecting it to the FT232H, but it has digital IO only. And my guess is that AC/DC is analog input.
SPW 2430 - https://www.adafruit.com/product/2716#technical-details
FT232H - https://learn.adafruit.com/circuitpytho ... 2h/pinouts
So two questions:
Am I correct that I can't use the spw2430 FT232H without an ADC converter?
And if I use a microcontroller with analog pins (I have some raspberry picos), can I read the values from AC and DC if i configure a pin as analog in?
dastels
Re: Wiring SPW2430
Post by dastels »
The outputs are analog. You will need a ADC to capture the data. Specifically you need to use the DC output connected to an analog input. All the information you need is in the description at https://www.adafruit.com/product/2716.
Post Reply
