buzzing mindfulness bracelet code plus some new functions
bozzaglia
Re: buzzing mindfulness bracelet code plus some new functions
Post by bozzaglia »
Here is a snapshot. Sorry I didn’t try it earlier
dastels
Post by dastels »
OK. You need to put the debouncer module in your CIRCUITPY/lib directory. You'll find it in the bundle: adafruit_debouncer.mpy.
bozzaglia
Post by bozzaglia »
Ok! I’m looking for the bundle you pointed on your website but I am having a hard time finding it. Could you please send the link?
bozzaglia
Post by bozzaglia »
I think I got it here:
https://github.com/adafruit/Adafruit_Ci ... g/20220817
I downloaded the circuitpython 7.x bundle at this link and found the file in the lib directory.
Do I have the right one?
bozzaglia
Post by bozzaglia »
ok, I got this message on the REPL
Incompatible .mpy file. Please update all .mpy files. See http://adafru.it/mpy-update for more info. I'm going to look at the link
dastels
Post by dastels »
Grab the bundle from here: https://circuitpython.org/libraries. You want the one that matches the version of CircuitPython you are using: 7.x or 8.x.
It sounds like you have a mismatch between CP and the library bundle. It's all covered at https://learn.adafruit.com/welcome-to-circuitpython.
bozzaglia
Post by bozzaglia »
I tried downloading the 8.x version, since the 7.x was apparently incompatible. The bundle name is "adafruit-circuitpython-bundle-8.x-mpy-20220817.zip".
I pasted the adafruit_debouncer.mpy file in the lib folder. Got the same incompatible message in the REPL. And now the gemma led cycles solid red - solid green - blinking green.
I attach the screenshot of my CIRCUITPY/lib folder
bozzaglia
Post by bozzaglia »
I started reading at the link but didn’t find a way to understand what version of circuit python is on my board.
dastels
Post by dastels »
If you connect to the REPL and CTRL-C to break out of the program it will tell you what version is running.
Or you could put a known version of CircuitPython onto the board. See https://learn.adafruit.com/welcome-to-c ... cuitpython.
If you are running some 7.whatever.whatever version of CircuitPython, you MUST ,use a version 7 library bundle. I suggest using the latest version 7 of CircuitPython from https://circuitpython.org/board/gemma_m0/ and the library bundle from https://circuitpython.org/libraries. Copy just what you need from the bundle's lib directory to CIRCUITPY/lib.
I suggest you delete everything from CIRCUITPY/lib, empty trash, and tyhen copy over what you need.
bozzaglia
Post by bozzaglia »
OK! I did everything you suggested:
  • installed the most recent 7.x Circuitpython (did all the "Gemmaboot" process as described). The version previously on the board was 5.0.0.
  • Downloaded the 7.x bundle at the link you sent me.
  • Wiped the CIRCUITPY/lib folder (it contained a folder named "adafruit_hid" and two files: "adafruit_dotstar.mpy" and "neopixel.mpy"
  • Emptied trash
  • Pasted in the CIRCUIPY/lib folder the same folder and files from the 7.x bundle.
  • Pasted the adafruit_debouncer.mpy file from the 7.x bundle
  • Pasted again the file BOOT.PY in the CIRCUITPY directory (took it from the downloaded folder "circuitpython_logger_boot / 7.x)
  • I also made sure that my button works by running a simple plotting code
After I did this I saved the CODE.PY file and got an error message in the REPL with the following:
File "code.py", line 5, in <module>
File "adafruit_debouncer.py", line 32, in <module>
ImportError: no module named 'adafruit_ticks'
So I found a file named "adafruit_ticks.mpy" in the 7.x bundle and pasted it in the CIRCUITPY/lib folder (NOTE: that file wasn't there before!)
I reloaded the code and the REPL this time didn't write anything at all. I did it twice to make sure.
The board led blinked a couple of times (don't remember the color) and then the led switched off and remained off. After some 10-15 minutes the buzzer went off once and right away the led turned to flashing red and nothing else happened.
Did I do something wrong? Help :-O
dastels
Post by dastels »
And nothing was output on the REPL?
bozzaglia
Post by bozzaglia »
I just tried it again (erased the code I used to test the button and saved my code) and got this on the REPL (I translated from italian):
Code stopped by auto-reload. Reloading soon.
soft reboot
code.py output:
File "code.py", line 28, in <module>
AttributeError: object 'DigitalInOut' doesn't have the attribute 'fell'
It never gave this message before... Could I have lost some pieces of code in the cut and paste process? I checked and doesn't seem so...
dastels
Post by dastels »
OK. The Debouncer has the fell property, not the DigitalInOut.
Please post your current code.
bozzaglia
Post by bozzaglia »
Here it is... now when I save it the REPL prints just this:
soft reboot
L'auto-reload è attivo. Salva i file su USB per eseguirli o entra nel REPL per disabilitarlo.
code.py output:
And the led on the gemma goes off and stays like that...
import time
import board
import random
from digitalio import DigitalInOut, Direction, Pull
from adafruit_debouncer import Button
pulsante = DigitalInOut(board.D2)
pulsante.direction = Direction.INPUT
pulsante.pull = Pull.UP
vibrating_disc = DigitalInOut(board.D1)
vibrating_disc.direction = Direction.OUTPUT
switch = Button(pulsante)
on_time = 4     # Vibration motor run time, in seconds
interval = random.randint(1, 1800)
delta = (1800 - interval)
start_time = time.monotonic()
while True:
    switch.update()
    timer = time.monotonic() - start_time  # timer è t tra start_time e time.monotonic
    if timer >= interval and timer <= (interval + on_time):  # avvia il motore
        vibrating_disc.value = True
    elif timer >= (interval + on_time) and timer <= (interval + on_time + delta):
        vibrating_disc.value = False
        if pulsante.fell:
            file1 = open("mindfulness_log.txt", "a")
            file1.writelines("interval, ok")
            file1.close()
        elif pulsante.short_count == 2:
            file1.writelines("interval, no")
            file1.close()
    elif timer > (interval + on_time + delta):
bozzaglia
Post by bozzaglia »
After a little while the buzzer goes off (like it would normally do with the random buzzing) and the led starts blinking red.
The REPL prints
Traceback (chiamata più recente per ultima):
File "code.py", riga 28, in <module>
AttributeError: l'oggetto 'DigitalInOut' non ha l'attributo 'fell'
Caricamento codice pronto.
Press any key to enter the REPL. Use CTRL-D to reload.
I push the button (which should create the file "mindfulness_log" and start appending my feedback, and nothing happens on the CIRCUITPY drive
BTW if I check the code on MU I get the green thumbs up
Post Reply
