Hi!
Was able to solder up the headers and switch cleanly to the PCB. The shield to worked with a Feather M0 for a few hours. After some sketch changes and an upload, reconnected the Feather to the PowerBoost. Flipped the switch to ON on the PowerBoost and it literally turned on for a second and then went off. Flipped the power switch a couple times, tried charging the LIPO. The CHG LED on the PowerBoost went on so I left it over night. The DONE LED never illuminated. So there is something wrong with the shield. Please help.
Thanks,
Heal
PowerBoost 500 Shield Stopped Working
- mikeysklar
Re: PowerBoost 500 Shield Stopped Working
Can you post a photo of the soldered up PowerBoost 500 shield.
Also of the battery you are using. Is it an Adafruit LIPO? If not can you post a photo of it with the leads and connector clearly visible?
- healwhans
See attached.
The LIPO was purchased from Adafruit, but it wasn't identified as an Adafruit LIPO.
Heal
Heal
- Attachments
- LIPO.png (408.31 KiB) Viewed 170 times
- PowerBoost.png (643.12 KiB) Viewed 170 times
- mikeysklar
Thank you for the photos. The soldering looks good.
The batteries orientation is correct. However, it looks like there is some what tape around the batteries wires and a second pair of red and black wires that I cannot make out what they are connected to. Can you elaborate on your setup?
- healwhans
That's the tape that came with the battery. It was used to hold the wires to the battery. All I did was remove the tape and wrapped it around the wires to keep them neat.
The battery was purchased from Adafruit P2011 http://adafru.it/2011
Thanks,
Heal
Thanks,
Heal
- mikeysklar
Okay, let’s try another board. Please e-mail [email protected] and request a replacement. Include your order# and a link to this forum thread.
