Hi, Now I am totally clear on what I need
I made a simple ble midi controller with a nrf52832.
https://learn.adafruit.com/web-ble-midi ... controller
I have this working but now I want to build one using the Adafruit Feather M0 Bluefruit LE. Is there a sketch that will allow me to do the same thing that I can do with my nrf52?
Feather M0 and sketches for midi
Re: Feather M0 and sketches for midi
This project does MIDI with a Feather Bluefruit LE:
https://learn.adafruit.com/bluetooth-le ... r/overview
- kingmichaelcoy222
I understand, but, the sketch requires neo pixel and the touch sensor right? Is the 15 step sketch the sketch you are referring to?
The NeoPixel code is independent of the MIDI code. You can safely ignore that and use the tutorial code as a reference for doing BLE MIDI with the board you're using.
- kingmichaelcoy222
Could you point to where the sketch is exactly because I dont think the 15step sketch is what im looking to use? Unless that is the correct one
- kingmichaelcoy222
Ok for the fifteen steps library for this board the library that uses the feather m0 in the style of midi control im looking for requires the touch sensor. basic sketch in that category works and uploads. it is a step sequencer. I want to have the functions of what the library requiring the touch sensor or the trellis.
- kingmichaelcoy222
I got it working with a midi guitar sketch that is made for the Adafruit 32u4 but I used it for a feather m0
