Trinket M0 turns on but doesn't connect to Arduino IDE
vidagabriel
Post by vidagabriel »
My trinket works, but it also doesn't...
Upon plugging in my trinket M0, the green and red LED's turn on, the red flashes for a bit, and then it's only the green ON light. I'm not seeing the purple LED turn on, and the Arduino IDE platform can't see the trinket.
I've done the following troubleshooting:
- used different cables
- checked all connections
- reset the trinket
I have 3 trinkets; two of them are working fine (code uploaded, running my sensors just fine) but this third one is driving me up the wall. I tested all my sensors using the working Trinkets so I know the sensor isn't causing the problem. Any idea why it's able to turn on but not connect to my PC?
adafruit_support_carter
Re: Trinket M0 turns on but doesn't connect to Arduino IDE
Are all 3 Trinkets the same model? The Trinket M0:
https://www.adafruit.com/product/3500
None of these are the older original Trinket?
https://www.adafruit.com/product/1500
