Flash OpenThread on Feather nRF52840 Express
remydemy
Post by remydemy »
Hei everyone,
I'm currently trying to flash OpenThread onto the Adafruit Feather nRF52840 Express, with the help of this Guide .
Hardware & Software I use:
  • Adafruit Feather nRF52840 Express, connected via USB.
  • I tried it on macOS and Ubuntu.
  • JLink version: 17.0.2
  • nrfjprog version: 10.17.3 external
  • Bootloader: UF2 Bootloader 0.6.2
When I try to flash my device I get the following Error Message:
ERROR: No debuggers were discovered.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
And if I run it with the --log flag enabled I get this in a log file:
[ info]: --------------------------------------------------------------------------------
[ info]: nrfjprog -f nrf52 --chiperase --program ot-cli-ftd.hex --reset --log
[ info]: nrfjprog version 10.17.3 external
[ info]: Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
[ info]: Library loaded, loading member functions.
[ info]: Member functions succesfully loaded.
[debug]: [ Client] - open
[debug]: [ Client] - start
[ info]: [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 4a6ee3a6-2ab7-4ca7-841c-942cb217da23.
[trace]: [ Client] - Command open executed for 11 milliseconds with result 0
[debug]: [ Client] - config
[trace]: [ Client] - Command config executed for 2 milliseconds with result 0
[debug]: [ Client] - enum_emu_snr
[trace]: [ Client] - Command enum_emu_con_info executed for 0 milliseconds with result 0
[debug]: [SeggerBackend] - Logger sink registered in Segger backend logger
[debug]: [  JLink] - Logger sink registered in JLink logger
[debug]: [  nRF52] - open
[debug]: [  nRF52] - just_check_family
[debug]: [SeggerBackend] - open_dll
[debug]: [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[ info]: [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.7.66.1.dylib.
[ info]: [SeggerBackend] - Library loaded, loading member functions.
[ info]: [SeggerBackend] - Member functions succesfully loaded.
[debug]: [SeggerBackend] - Set batch mode
[debug]: [SeggerBackend] - dll_version
[ info]: [SeggerBackend] - Segger dll version 7.66.a loaded.
[trace]: [ Worker] - Command open executed for 4 milliseconds with result 0
[debug]: [  nRF52] - config
[trace]: [ Worker] - Command config executed for 2 milliseconds with result 0
[debug]: [  nRF52] - enum_emu_con_info
[debug]: [SeggerBackend] - is_connected_to_emu
[debug]: [SeggerBackend] - enum_emu_con_info
[trace]: [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
[debug]: [  nRF52] - close
[debug]: [SeggerBackend] - close
[debug]: [SeggerBackend] - disconnect_from_emu
[debug]: [SeggerBackend] - Segger Backend closed.
[debug]: [  nRF52] - nRF family DLL closed
[trace]: [ Client] - Command close executed for 10 milliseconds with result 0
[debug]: [ Client] - terminate
[trace]: [ Client] - Command terminate executed for 0 milliseconds with result 0
[trace]: [ Worker] - Command close executed for 10 milliseconds with result 0
[trace]: [ Worker] - Command terminate executed for 0 milliseconds with result 0
[trace]: [ Worker] - Executed 5 commands for 16 milliseconds
[debug]: [ Client] - Child process terminated with result 0
[debug]: [ Client] - Worker process exited with code: 0
[trace]: [ Client] - Executed 5 commands for 23 milliseconds
So basically flashing doesn't work but I don't know why and I can't really see any problem in the log file. Has anybody any idea or can help me in any way?
Is it possible that I need the SEGGER J-Link Debugger?
Thank you for any help.
Best regards,
Emily
adafruit_support_carter
Re: Flash OpenThread on Feather nRF52840 Express
Return to “Microcontrollers”
