Using feed save() and deepsleep problem
tubos
Post by tubos »
1) In the code when going to sleep after the Temp-save() no data is received at my feed in adafruitIO
When i add a delay (see **1) before i go to deepsleep the values are received.
Is this normal? or is there a better alternative?
See code below
2) is io.run() required if i just send data to adafruit.IO ?
  io.run(); // Required at top of the loop to process incoming data
  Serial.print("sending -> ");
  int rndtemp = random(255);
  Serial.println(rndtemp);
  if(!Temp->save(rndtemp)) { // Send value to feed
    Serial.println("failed to send value");
  delay(500); // **1
  Serial.println("Going to deepsleep");
  ESP.deepSleep(15e6);
brubell
Learn User Page
Re: Using feed save() and deepsleep problem
Post by brubell »
You'll want to place io.run() at the bottom of the loop, after the device sends data to adafruit io. Take a look at our deep sleep example - https://github.com/adafruit/Adafruit_IO ... psleep.ino
tubos
Post by tubos »
Thank you good tip , it works great now.
I was confused by the comment in the publish example :
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
brubell
Learn User Page
Post by brubell »
fantastic!
alexbrugh
Post by alexbrugh »
Thank you for the delay 500 suggestion. fixed my post-ssl-removal issue as well.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
