Adafruit Music Maker MP3 Shield
Woodyguitary
Post by Woodyguitary »
Hi there,
absolute newbie here, so sorry in advance.
Project: Play random songs (file structure: 1.mp3, 2.mp2, ..., 328.mp3) from SD card when some sensor is being triggered.
I worked out how to gerenate a random file name.
But when inserting it in "musicPlayer.playFullFile() nothing happens.
Ive been working on this issue for hours now and I cant seem to figure it out.
I appreciate any help!
My Code:
itoa(random(1, 329), voiceline, 10);
  strcat(voiceline, ".mp3");
    Serial.print(F("Playing   "));
    Serial.println(voiceline);
    musicPlayer.playFullFile(voiceline);
The serial monitor will display the file names as intended, but no sound whatsoever.
Ive also tried different versions of whats in the () like:
musicPlayer.playFullFile("/voiceline")
or
musicPlayer.playFullFile("/'voiceline'")
but nothing works.
Looking forward to help. Many thanks!!!
adafruit_support_mike
Re: Adafruit Music Maker MP3 Shield
You shouldn't need an initial slash.
Try stepping back to one of the example sketches that come with the Music Maker library. Can you play a single file with that?
Woodyguitary
I figured it out.
letting the music play with
is working fine.
However, something seemed to be wrong with the created file names.
Its working with
sprintf(voiceline, "%02d.mp3", random(1,329));
However, I would appreciate it, if someone could explain to me, why this works, and the other approach doesnt.
Hope that helps anyone else also.
Try printing the filenames your random routine generates. You may be getting something unexpected.
