Feather M4 DMX
afox
Feather M4 DMX
Post by afox »
Hi all!
I am trying to send DMX packages via an Feather M4, and a custom-made PCB that drives a MAX485 IC.
So far I am using UART with 250000 baud and SERIAL_8N2.
After slightly modifying the Arduino Variation File to use a dedicated SERCOM handler I got some good looking DMX packages.
Unfortunately, I need to adjust the baud for the BREAK frame of a package.
Currently, no DMX light can process my sent DMX packages because of that problem.
I am debugging the signal via a scope to see the timings and also I am able to analyze correct signal sent from a USB DMX interface.
I am setting the baud rate for the BREAK frame as following:
SERCOM5->USART.BAUD.FRAC.FP
SERCOM5->USART.BAUD.FRAC.BAUD
But i am stuck with calculating the right values here...
Thanks in advance!
Regards,
Alex
adafruit_support_mike
Re: Feather M4 DMX
I'm afraid we don't have any experience with DMX timing. Your best bet would be to check the documentation for the lights you're using and see if you can find a timing schedule.
Return to “Microcontrollers”
