Is there any way we can auto arrange the layout of blocks in the dashboard. I used the row and column when I create them via HTTP Post. but they always go to first location and added after the last one.
thanks
Dashboard auto layout
- Luraco
Re: Dashboard auto layout
Any json command to arrange the dashboard blocks for LG display?
- jwcooper
Here is a previous forum post on how to use the blocks api (mostly used internally) to position blocks. Set the row and column in the json:
viewtopic.php?p=898219&hilit=io+api+blocks#p898219
- Luraco
I am sending the row and column but is not working.jwcooper wrote: ↑Tue Sep 06, 2022 2:33 pm Here is a previous forum post on how to use the blocks api (mostly used internally) to position blocks. Set the row and column in the json:
{"column":4,"row":4,"visual_type":"momentary_button","size_x":1,"size_y":1,"properties":{"text":"System Status","value":"1","release":"0"},"block_feeds":[{"feed_id":"21031222-p"}]}
Here is the screen shot of the json reply. dashboard image Block info row and columns are empty even size too.
