pxt-hiddmesg
Microsoft's MakeCode platform for easy blocks-style programming
_david_f
pxt-hiddmesg
Post by _david_f »
Does anyone know how to get the "pxt-hiddmesg" tool running?
https://makecode.com/cli/hiddmesg
mikeysklar
Re: pxt-hiddmesg
Post by mikeysklar »
You can turn it on through enabling profiling as described here:
https://github.com/microsoft/pxt/blob/m ... n-hardware
Profiling on hardware
It's currently only supported on STM32F4. You enable it with ?compiler=profile, as above.
There will be no automatic dumping of profile counters, but you can use control.dmesgProfileCounters() which will dump them to DMESG buffer (you can fit maybe 1 or 2 dumps in the buffer). Then run pxt hiddmesg, while your device is connected over USB, which will show the profile on the console. If you have a hardware debugger, you can also run pxt dmesg. The format is simpler than in JavaScript - it shows the number of calls, total time in microseconds, and the counter name.
_david_f
Re: pxt-hiddmesg
Post by _david_f »
When I enter "?compiler=profile" before "#editor", as mentioned in the link you posted, I cannot download the "uf2" file anymore, instead I get this message:
"The hex file is not available, please connect to internet and try again."
Of course I am connected to the internet.
mikeysklar
Re: pxt-hiddmesg
Are you using a STM32F4 based board?
Are you already building code from the command line where you could use:
PXT_COMPILE_SWITCHES=profile
Return to “MakeCode”
