What UUID does Bluefruit::Scanner::filterUuid() look for?
- jaholmes
Advertising a BLEService with 128-bit UUID x on one Feather device and scanning/filtering for it on another doesn't appear to work, so pretty sure I'm not understanding something here. What UUID is filterUuid() actually looking for, and how, on the service side, do I specify it?
- jaholmes
Re: What UUID does Bluefruit::Scanner::filterUuid() look for?
I suppose I should explain "doesn't work." To be clearer, I'm running the following BLEScanner sample:
https://learn.adafruit.com/bluefruit-nr ... blescanner
I can see my service advertised like so in the Arduino serial monitor:
(The garbage characters before the UUID are printed because of a bug in the sample's printUuid128List() function. There are two format specifiers in the printf() call, but only one has an argument provided for it.)
My service's UUID is 53717BD8-7885-4BE4-B7F2-EC5350BE1454. I supposed that adding a filterUuid() call to the sample with this UUID would limit the scan results to my own service, however the scan then returns no results. Again, pretty sure I'm just misunderstanding what UUID this filter operates on. A nudge in the right direction would be very much appreciated!
[ADV 15655] Packet received from F4:2F:AE:19:3F:D4
PAYLOAD 31 bytes
02-01-06-02-0A-00-11-07-54-14-BE-50-53-EC-F2-B7-E4-4B-85-78-D8-7B-71-53-06-08-53-6C-6F-74-44
RSSI -61 dBm
ADV TYPE Connectable undirected
SHORT NAME SlotD
TX PWR LEVEL 0
128-Bit UUID T⸮PS⸮⸮⸮K⸮x⸮{qS53717BD8-7885-4BE4-B7F2-EC5350BE1454
